Other The Bit-Tech Component: Wish and You May Receive Thread
Discussion in 'General' started by TheGreatSatan, 4 Feb 2014.
  1. IamJudd
    IamJudd Modder
    30 Oct 2011
    I wish for someone to PM me with advice on upgrading my existing rig that errs towards a lower power consumption but retains good frame rate on fps!
    Sent from my iPad using Tapatalk
  2. KayinBlack
    KayinBlack Unrepentant Savage
    2 Jul 2004
    Anyone got a stock Intel cooler for a 3570k? I need to get this machine up and running and check it for faults. I can't do that with a waterblock attached to no system. I can get everything else sorted I think.
  3. Comrade Woody
    Comrade Woody Obsolete
    14 Mar 2011
    I'd be grateful for one or two PC2-5300 or PC2-6400 SODIMMs if anyone has any lying around, either 1GB or 2GB, to upgrade an old laptop for a friend. He currently has a single 1GB PC2-5300 module installed, so just another 1GB would make a difference (the max supported is 4GB, 2x2).
  4. lancer778544
    lancer778544 Multimodder
    5 Jan 2011
    I've got a single 2GB DDR2-800 stick or a matched pair of Samsung 1GB PC2-5300S if they're of any use? I will admit I have no idea if they work and I haven't got a DDR2 laptop to try them in unfortunately.
    Comrade Woody likes this.
  5. lilgoth89
    lilgoth89 Captin Calliope
    12 Mar 2011
    anything now ive lost all my computers to the police while they investigate false allegations
    having world of tanks / killing floor withdrawal symptoms
    been gifted an old 8600gt so I might be ok for graphics
    ill donate / return it once the police finish with my gear ( in about 6 - 8 weeks or so... )
  6. NIHILO
    NIHILO The Customer isn't always right!
    30 Dec 2013
    A moderatly used 780GTX for around $400 CND would be great. I can image that should be a fair price for a used card.
    As long as it works and it doesnt die on me in the next few years ill be happy.
  7. Comrade Woody
    14 Mar 2011
    Yes please, thank you. I'll send you a PM :)
  8. Comrade Woody
    14 Mar 2011
    Received today Chris, thanks again. I tested them all and they all worked, I've used the 2GB module in the laptop and put the other two back on here as a donation with some DDR3 I had lying around :)
    The donation can be found here in case anyone's interested: http://forums.bit-tech.net/showthread.php?p=3514629#post3514629
  9. bdigital
    bdigital Is re-building his PC again
    10 Aug 2010
    A windows 7 HP key (legit of course).
    I could bring my brothers pc into inti the present day!
    Sent from my GT-I9505 using Tapatalk
  10. TheViscountGodrich
    TheViscountGodrich Wannabe modder.
    12 Apr 2014
    I'm building my first real mod but im broke. I'm very worried that I won't be able to afford any overclock able parts. I could really use a gtx770 or i5-4670k. That or a good mini-itx motherboard.
    thanks.
  11. Darkwisdom
    Darkwisdom Level 99 Retro Nerd
    27 Aug 2011
    A board that is capable of SLI that is compatible with my ivybridge CPU. I really want to go SLI with my GTX 670 Direct CU II 4GB but man... I don't even have an extra slot that's useful.
    That'll show me for buying a cheap board just so I could upgrade.
  12. Shirty
    18 Apr 1982
    If anybody fulfils any of these requests then they are frankly a saint.
  13. Impatience
    Impatience Minimodder
    6 Apr 2014
    UV Orange PSU cable extenders? (ATX, 6-pin, SATA's, USB & Front Panel) I'm just totally broke atm, dont want to risk my PSU's warranty (while i'm broke) and CAN'T STAND the standard Corsair Black cables! A Fully Modular PSU would be awesome (i'm only using a 430w atm) but too expensive for me right now! :(
  14. mansueto
    mansueto Too broke to mod
    31 Aug 2007
    Someone want to give me a half decent entry-level / junior position job to start my career?
  15. Pookie
    Pookie Illegitimi non carborundum
    4 May 2010
    A replacement X58 board would be nice. Mine takes a few attempts to power up. Once booted it's fine and restarts are ok too. Even bought a new PSU hoping that would fix it.
  16. bigkingfun
    bigkingfun Tinkering addict
    27 Jul 2008
    .....I know my HW is a bit yesteryear:rolleyes:
  17. Landy_Ed
    Landy_Ed Combat Novice
    6 May 2009
    Some faster bigger ram for a P67 board, I seem to be stuck on 4x2gb 1600 stuff
  18. RedFlames
    23 Apr 2009
    Yours too? Mine the sata controller crapped out...
  19. CrapBag
    CrapBag Multimodder
    17 Jul 2008
    It's a pity your in canada, I've got a 1.9ghz x2 3600 your could have had, probably would have overclocked that extra 100mhz easily.
  20. Pookie
    4 May 2010
    I think you have it worse than me. Once it starts it's fine. Probably capacitors degrading or something like that. It has always been overclocked so I guess it's wearing out.
