Education Today I learned (TIL)........
Discussion in 'General' started by Kronos, 20 Jan 2018.
  1. The_Crapman
    5 Dec 2011
    Ah ha! here it is. It was a couple of weeks ago, but i've only just found out the turbo buttons you used to get on pc's actually made them UNDERclock, so they would run software/games designed to run at lower clockspeeds.
  2. Sentinel-R1
    Sentinel-R1 Chaircrew
    13 Oct 2010
    Yep, my first pc (a 486 DX2-66) had a turbo button that would switch clock speed between 16 & 66MHz.
  3. Gareth Halfacree
    4 Dec 2007
    It's 'cos back in the day you had one speed of processor, and that was your lot. What's the easiest way to do timing-related stuff? Tie it directly to the processor clock. Need to wait X amount of time? Just throw in a loop with Y number of NOPs, job done.
    Then we ended up with multiple speeds of processor, and that didn't work any more. Developers moved to actually timing things - though "measure how long it takes to do X then use that to count the number of NOPs we need" was still a thing - but older software rarely got updated. The Turbo Button was the solution: you could either run the CPU in compatibility mode at a slower clock speed, or at its full native speed. "Slow Button" isn't a great marketing tool, though - although "Compatibility Button" would have worked - and thus the "Turbo Button" was born.
    Sentinel-R1 likes this.
  4. Mr_Mistoffelees
    26 Aug 2014
    TIL, it's never too late to exhume an old thread...
    adidan and The_Crapman like this.
  5. Byron C
    Byron C I was told there would be cheesecake…?
    12 Apr 2002
    Mr_Mistoffelees likes this.
  6. Guest-44638
    Guest-44638 Guest
    I'll be honest I was waiting for a tirade of 'Necro...', but it seems only the context of the thread is the decider for that - maybe sometimes the poster (but that would be discrimination, iirc).
  7. fix-the-spade
    fix-the-spade Multimodder
    4 Jul 2011
    TIL that Autodesk Sketchbook now has the complete Copic marker colour index installed in it as standard, all present, numbered and grouped the same as the marker sets.
    This made me so much happier than is probably healthy.
    The_Crapman likes this.
  8. RedFlames
    23 Apr 2009
    Is that available to the free offering or is it one of the pro/paid add-ons? IIRC Sketchbook was pretty decent and not to price gouge-y... by autodesk standards at least.
  9. fix-the-spade
    4 Jul 2011
    It's in the free one but you have to create an account.
    RedFlames likes this.
  10. VipersGratitude
    VipersGratitude Multimodder
    4 Mar 2008
    Magenta is imaginary
  11. fix-the-spade
    4 Jul 2011
    It's real enough, Mauve is the one that doesn't exist (it's just Purple being a hipster).
  12. legoman
    legoman breaker of things
    28 Feb 2010
    Trying to photograph Day Glo colours is nigh on impossible.
  13. The_Crapman
    5 Dec 2011
    If you had worked every day since columbus set sale for India, at a rate of £5000/day, you would still not be a billionaire.
    Set sail 03/08/1492 - 192,548 days to date
    192548X£5000= £962,740,000
  14. fix-the-spade
    4 Jul 2011
    National Express buses have onboard media servers.
    They are not loaded with the song.
  15. Byron C
    12 Apr 2002
    I'm going to regret asking this but... which song?
  16. Arboreal
    21 Jan 2011
    I'm guessing it'd be National Express by the Divine Comedy
  17. Byron C
    12 Apr 2002
    Aaahhhhh yes, that song.
  18. Arboreal
    21 Jan 2011
    (TIL) That Windows 10 doesn't fully support older GPUs.
    Put an ATi 4670 into a win 10 PC and found that there is no driver support other than the basics.
    I plugged 2 monitors in, and couldn't find any multi monitor options other than them showing the same content.
    I'm now looking for something newer and inexpensive that will do the job of providing an extended desktop.
  19. RedFlames
    23 Apr 2009
    iirc the most recent amd driver for the 4670 didn't even support Windows 8.1.
  20. Guest-44638
    Guest-44638 Guest
    Just had a look at how old the HD 6670 is in my wife's PC... 2011 -- was Win10 even thought of back then...? o_O
