Case Mod - In Progress A380 Mod- update
Discussion in 'Project Logs' started by Roboduck, 7 Jan 2010.
What colors shold the case be?
  1. Red and White
    60 vote(s)
    55.6%
  2. Blue and White
    11 vote(s)
    10.2%
  3. All black with LEDs
    13 vote(s)
    12.0%
  4. All white with red fans
    16 vote(s)
    14.8%
  5. All black no lights
    2 vote(s)
    1.9%
  6. Other?
    6 vote(s)
    5.6%
  1. stuartwood89
    20 Aug 2008
    Better... :)
  2. Roboduck
    Roboduck 01110001 01110101 01100001 01100011
    1 Dec 2009
    Only one problem with that, the box is 7.5"x7.5"x3.5" a 250mm fan is 8.5" across :D
  3. mnpctech
    mnpctech bit-tech sponsor
    21 Apr 2003
    Came out nice!
    Your Honeycomb Modder's mesh should arrive today or tommorrow! :thumb:
  4. Roboduck
    1 Dec 2009
    Thanks again! Sweet mesh and MNPCTECH shirt to boot!
    And the organ donor came today too!:dremel:
    and here it is 10 mins out of the box....
    Ill admit the fans are kinda cool, I might have to use them in a future project.
    After getting both cases apart I had an idea I want to try out. :D
  5. Roboduck
    1 Dec 2009
    And with a little bondo magic I now have a front bezel (mockup or possibly final product)!
    A couple drill holes later and the second duct is mounted to the scrap side panel.
    Now with lights! The white looks SOOO pretty....
  6. disturbed13
    disturbed13 Minimodder
    28 Nov 2008
    thats looking awesome!!!!!!
  7. grritsshawn
    grritsshawn I'm not insane I'm a modder
    20 Apr 2009
    do ppl often check for planes outside when you start your computer?
  8. disturbed13
    28 Nov 2008
    no they try to check in their luggage and look for a metal detector :D
  9. stonedsurd
    11 Mar 2009
    That shirt is awesome. I've had someone stop in me in the middle of a crowded marketplace in india and ask me if I was a case modder. Wear with pride! :thumb:
    Oh, and the front looks awesome already.
  10. GinoTheCop
    GinoTheCop MKA
    10 Oct 2006
    That "twin engine" looks like its almost cleared for take off.. Already looking great and am sure will be a killer when finished..
  11. Mr_Wongy
    Mr_Wongy What's a Dremel?
    8 Oct 2008
    This looks EPIC, like the idea with the control box Ill be watching.....If i can look into the wind.
  12. stuartwood89
    20 Aug 2008
    Excellent what you did with the front bezel there. Looks like you just saved yourself a heap of time and money by using the front from the other case.
  13. imersa
    imersa Parvum Princess
    9 Apr 2009
    White lights are the way forward
  14. Shadow703793
    Shadow703793 What's a Dremel?
    5 May 2009
    Make it bigger? :D
    Anyways, those are RGB LEDs on the fan right? Good work btw.
  15. benji2412
    benji2412 <insert message here>
    25 Apr 2009
    I want an update!! :D
  16. Roboduck
    1 Dec 2009
    Thanks everybody!
    Sorry I am out of town for the weekend. No update until Monday, sorry :(
    Thanks! I hope so, it will need a lot of shaping to get the transition between the two ducts to look good, but that saves me almost $120 in plastic or aluminum. The bezel is shorter than the original design, meaning there won't be a top and bottom duct but that's not necessarily a bad thing. Now there is a lot of extra room on the top and bottom panels (third fan maybe?) Plus without a duct on the bottom I can now use different case feet (stock ones are plastic fold out and ugly!).
    Thank you! lol I don't think I want to make it any bigger I just got done making it smaller!
    Yes they are "256 color" RGB LEDs on the fans that came out of the A380Color. They are kinda cool but there is no good way to choose what color you want. There is a button that cycles through the colors and you can press it to lock into a color.
    I will proudly rock the modders shirt! :rock:
    Edit: I also think it may be time for a new name. The association with the A380 jet was an unintended coincidence. I knew what I wanted to build but didn't have a name and EPIC A380 was the first thing that popped into my head.
  17. mnpctech
    21 Apr 2003
    Lookin good dude :thumb:
  18. DeadP1xels
    30 Nov 2009
    Lookin nice :)
  19. AnG3L
    AnG3L Ultimate Modder
    19 Mar 2009
    Very nice job you did there man, I had the same plan in my mind and I am glad to see that unfolding really nice!
  20. Roboduck
    1 Dec 2009
    I decided to play around with the design and colors a little. Since the bezel I made from the two cases doesn't match the original concept I thought I would work up an additional concept to get some opinions.
    This is closer to what the case will look like if I follow the original design and color scheme.
    -White interior and main exterior
    -Red accent on ducts and fans
    -2x 120mm fans on top and bottom
    Here is the new concept I came up with. I still like the White and red but after seeing the glowing white interior inside a black exterior I like the color scheme there too. (Im not sure why the render turned out so grey but It should be a gloss white)
    -White interior
    -Black Exterior
    -White Fans
    -3x 120mm fans (for possible future water cooling)
    Let me know what you think!
