Case Mod - In Progress [Build Log] Arctic Water
Discussion in 'Project Logs' started by B NEGATIVE, 18 Nov 2012.
  1. B NEGATIVE
    B NEGATIVE All Hail Kim Jong Magoo!
    8 Aug 2011
    Small progress....
    Knocked the copper back with 1600 W/D ready for some bench polishing (when the bloody thing arrives)
    Holding off the final profiling of the corners until i have some pumps in.
    Brightens up an otherwise ordinary pump top....wishing for a drill press too i think,would of made the hole drilling much easier than the trusty 18v cordless...
  2. KrunchR
    KrunchR What's a Dremel?
    22 Apr 2008
    nice work as usual, Neg. machine Mart do some cheap drill presses. mine. My clarke has lasted years!
  3. Overminde
    Overminde What's a Dremel?
    15 Sep 2011
    Subbed, very nice build.
  4. Psyance
    Psyance What's a Dremel?
    6 Dec 2012
    Very nice copper work, subbed and looking forward to updates :)
  5. B NEGATIVE
    8 Aug 2011
    Some progress.
    Fans and rads painted and soon to be fitted,got some 240 rad stands coming so i can clear out the bottom bay.
    I could of got a pair of 360 rads in the space under there!
    Top 360 in,this will have a mesh cover over the rad face or may make a rad guard out of copper sheet....Time took get hammer out!
    Top panel painted.
  6. k.3nny
    k.3nny Minimodder
    27 Jan 2010
    comming out nicely!
    Are those Copper rings? :O
  7. B NEGATIVE
    8 Aug 2011
    Copper.......painted.
    Sorry K.3nny. :D
  8. k.3nny
    k.3nny Minimodder
    27 Jan 2010
    They look pretty real :p
  9. The_Crapman
    5 Dec 2011
    They do look awesome. what paint did you use on the rings?
  10. B NEGATIVE
    8 Aug 2011
    Ye olde faithfull PlastiKote.
  11. The_Crapman
    5 Dec 2011
    seems they've got 3 different coppers. lol is it Copper Brilliant Metallic (no.162), Copper Metallic, (no.4400) or Flat Copper Metallic (no.453)?
  12. siliconfanatic
    siliconfanatic Johny-come-Lately
    10 Sep 2012
    I. I....i......i.....fracking hate touch screens:grr:
    Just got an idea. On a gloomy, brain-currently underclocked day. I just got an idea.
    MY GOD, ITS FULL OF
    COPPER and carbon!
  13. damien c
    damien c Mad FPS Gamer
    31 Aug 2010
    Yao can fit a 360mm rad in the bottom, but it would depend on how thick it was as to how many you could fit.
    I managed to fit 1 360x60mm in the bottom with fans on both side for push/pull, but that didn't leave room for much more.
    If you got rid of the supports for the midplate and made some new ones you would find it easier to fit them in the bottom, because otherwise you have to fit all the fans bar one if you go push/pull and jiggle it in and then fit the final fan.
    As for the log I will keep a eye on this :thumb:
  14. B NEGATIVE
    8 Aug 2011
    Sorry about the wait,I have been waiting for forever for my sheet metal bender.
    Thankfully it arrived today so i got on with the shrouds and rad mounts
    Lower bay has been cleared of all the excess junk so i can get to work.
    In the bay.
    The PSU end of the shroud will be detailed with a plexi window to show off the PSU
    You can see the midplate is in,the pump mount is cut and ready to fit and the first of the rad mounts in the lower bay is done.
    I will be getting the rad mount on the other side finished and the shroud for the drive bays done.
    Once all the metal work has been done then i will move on to finishing the paint work.
  15. siliconfanatic
    10 Sep 2012
    Now i'm happy again! I got my fix of copper :D
  16. Marquee
    Marquee Mac Pro Modder
    22 Jul 2005
    Nice work. I like the colour scheme and that shroud is sexy.
  17. B NEGATIVE
    8 Aug 2011
    And the other side.
    Cant do one side and not the other,this is a double sided case design so it has to look good front and back.And for the other side...
  18. siliconfanatic
    10 Sep 2012
    So wait... both pairs of fans are blowing into the lower compartment :eyebrow:... But hey,You know what your doing :thumb: so I'll happily sit here and watch for the reason of this in the further modding :dremel:
    I'm afraid I must ask this too. Didn't think of it before now.
  19. B NEGATIVE
    8 Aug 2011
    I will dig the cap out for you.
    A little teaser....
  20. siliconfanatic
    10 Sep 2012
