Case Mod - In Progress [Build Log] Arctic Water
Discussion in 'Project Logs' started by B NEGATIVE, 18 Nov 2012.
  1. Cheapskate
    13 May 2007
    oh YEAH. That kicks the stock Corsair colors in the can.:D
  2. Waynio
    Waynio Relaxing
    20 Aug 2009
    That copper paint really looks like copper, nice. :D
    Completely missed this one until now, looking very nice. :clap:
  3. B NEGATIVE
    B NEGATIVE All Hail Kim Jong Magoo!
    8 Aug 2011
    Thanks man,I did wonder where you got too....:D
    Omega Stalker has settled on what he wants 'under the bonnet' as it where.
    3770k and a Z77 Sabertooth,this is the second one I have used as they just look and perform great!
    A good choice all round from what i see!
    Just need to breadboard it all for problems before i mod the armour and ram.
    Initially there was a 3570 going in but Omega found a 3770k in his price bracket and jumped on it fast,wise move i think.
  4. imersa
    imersa Parvum Princess
    9 Apr 2009
    I'm ready to see more now :D
  5. B NEGATIVE
    8 Aug 2011
    You know whats coming.
    AverageNinja likes this.
  6. AverageNinja
    AverageNinja Almost an EpicNinja
    6 Aug 2012
    Nice component choices B-Neg.!
    Ah doggy doggy doggy :D I absolutely love your dog dude :D
    Magoo for president :)
  7. Editor22
    Editor22 E22 | Hex-Gear
    3 Jan 2009
    LOL!
    Looking good so far dude!
  8. B NEGATIVE
    8 Aug 2011
    First irritant of the day...
    Coolermaster make a PSU mounting bracket for this case,shame it doesnt seem to fit without removing the PSU fan grill....
    Interesting.....someone wasnt thinking.
  9. AverageNinja
    6 Aug 2012
    Annoying! Maybe you can vile that thing a bit so it'll fit?
  10. Cheapskate
    13 May 2007
    Noted. I'm making a PSU bracket. I guess I should'a expected non-spec PSUs. Couldn't you just bend the end of the grill in a bit? -You know, the classic 'force it to fit' kinda thing?
    Better Magoo caption: "MSI? -Meh!"
  11. B NEGATIVE
    8 Aug 2011
    Even the screws with the grill in are too high....
    I might just leave it off,the PSU is fan side down anyway.
    I will say this,the AX860 doesnt look or feel as well made as the AX850,the casing looks cheap and less well finished..
  12. KoSoVaR^
    KoSoVaR^ Professional Sleever & Modder
    19 Dec 2010
    i want to see more copper awsomeness !
  13. siliconfanatic
    siliconfanatic Johny-come-Lately
    10 Sep 2012
    Holy Crud!
    I leave for few days and I get slapped in the face with a troll of updates!
    Sooooo-hoo many new projects to oogle at!
    Looking good!
  14. B NEGATIVE
    8 Aug 2011
    So,the bottom rad bay is done on the windowed side and the main components are in for the pre-mod shake down
    Forgive the pic quality,using my cam phone.
    There will be thin clear plexi strips across the opening like a grill.
    More Alu coming tomorrow for the interior,im aiming to get the whole lower rad bay finished,pumps mounted and all the plastics back on by weekend (better pictures as well!)
  15. siliconfanatic
    10 Sep 2012
  16. jinq-sea
    15 Oct 2012
    I'm keen to see MORE!!
  17. k.3nny
    k.3nny Minimodder
    27 Jan 2010
    looking good as it goes !:)
  18. B NEGATIVE
    8 Aug 2011
    Thanks guys!
    Sorry about the delay,cant find my flash card for my DSLR so its cam pics for this little update.
    Midplate in and painted
    And the pump top is mounted,the copper top is missing as it needs polishing.
    Front shot showing the copper accents on the drop down panel.
    The res are off to Tom at Chilled PC for the front ports to be drilled and tapped.
    I was going to attempt this myself but Tom is great at what he does and charges a very reasonable rate,I would be mad not to get him to do it!
    Next stop,getting the hardware in for its shake down before hitting it with teh paint gun.
  19. siliconfanatic
    10 Sep 2012
    Here comes that moment of the build: If something bursts into flames, no surprise. If not, THEN you proceed to shitbrix :hehe:
    Looking good! :thumb: have some rep for the copper ;)
  20. Waynio
    Waynio Relaxing
    20 Aug 2009
    I had same problem with corsair PSU grill, had to remove it & replace with one of my own. :D
    Makes it the wrong dimensions & they need to improve that, they make awesome PSU's & then spoil it with such a small detail forcing you to void the warranty to make it fit, not good.
    Project is looking good though. :):clap:
