Scratch Build – Complete Cor Leonis
Discussion in 'Project Logs' started by Attila, 28 Feb 2011.
  1. Archtronics
    Archtronics Minimodder
    27 Jun 2006
    Quality work better than any commercial cases, btw what's your day job :p
  2. Nexxo
    23 Oct 2001
    Is it wrong that I just squealed like a little girl?
  3. Ilias78
    Ilias78 What's a Dremel?
    23 Jul 2012
    Attila, fantastic and very-very inspiring work you are doing there... what you do, motivates and sparks up our creativity as modders. Thank you so much! :)
  4. teacherboy
    teacherboy Part Carbon/Nylon/Bovine
    29 Jan 2012
    Wow Attila - that is a work of beauty.
    MOTY and MDPC feature for sure :jawdrop::jawdrop:
  5. rak500
    rak500 Minimodder
    22 Aug 2009
    This is your best build yet, it's just so good.
    I was a massive fan of the previous ones but this is unbelievable. I can't remember the last time it took me this long to go through pictures.
    MOTY, and why not MOTdecade?
  6. Tangster
    23 May 2009
    I wish I had the time and dedication to make something even 1/10th as awesome. Stunning work.
  7. SuicideNeil
    SuicideNeil What's a Dremel?
    17 Aug 2009
  8. Pranja
    Pranja Blackwolf
    18 Dec 2011
    I don't know what to say,so I will say-this is beautiful case.
  9. woodyb
    woodyb What's a Dremel?
    16 Sep 2012
  10. Nexxo
    23 Oct 2001
  11. jeckulz
    jeckulz What's a Dremel?
    18 Jan 2011
    Semen has no corrosive properties on keyboard plastics right?
  12. Frido
    Frido Minimodder
    19 Apr 2007
    What he said! +1 and all!! :)
    /Frido
  13. tekonivel
    tekonivel Minimodder
    14 Jul 2012
    AMAZING!!
  14. Attila
    Attila still thinking....
    22 Feb 2008
    Be my guest. :lol: And thanks.
    Thanks Craig. :thumb:
    Thanks mate. :thumb:
    Seriously, you need to change your pants. :hehe: Thanks. :thumb:
    Thanks Wayne. Yeah the black and polish together is achingly pretty. :thumb:
    Money? Money? Where? :lol: Thanks.
    Long time me no look you stone. :hehe: Thanks. :)
    Don't give up. Never give up. It just isn't beyond you if you REALLY want to do it. ;)
    Thank you. I'm unemployed now so lets hope all the hardware works. :worried:
    Er, nnno, go ahead. :hehe:
    Thank you. :)
    Thank you. :)
    Thank you, but hang on a minute it's not finished yet. :hehe:
    Thank you. :)
    :D
    Thank you. :)
    :D
    Nah........No. Wait... I don't think so. :blush:
    Thank you. :)
    Hooked up the cables for GPU and the two hard drives.
    Plenty of room here for ninety degree cables.
    Unbeknown to me at the time of making, the GPU block takes one of the four mounting holes so I can only use three. But the card is very firmly fixed with just the three screws.
    So here is the basic plumbing scheme around the two blocks.
    I want to have 'hard' pipes going around to the back and then connect to plastic hose for the rest. This is purely aesthetic.
    I need some advice here though. In these photos you can see that I've had to use several extensions because 50mm seems to be the largest I can find. I need two 60mm and two 110mm extensions to make it with one part per line. Does anyone know where I can buy these or get them made?
  15. andrew8200m
    andrew8200m Multimodder
    4 May 2009
    That looks absolutely awesome!!! An idea tried a few times before and failed by all! No failing involved yet I see :D
  16. alain-s
    alain-s Minimodder
    12 Jan 2011
    What a beauty Attila! About the pipes U can always try to make the pipes your self with 12mm copper pipes. If U use Bitspower Crystal link fittings(C47). But if U going to buy some at a hardware store make sure U check the O/D of the pipes before U buy them. In the US and Australia the size of the pipes is 12.7mm these wont fit in the fittings.
  17. Combatus
    16 Feb 2009
    Holy crap, some of this looks so good I thought they were renders! :D:rock:
    It looks edgy too - awesome work Attila.
  18. Dark~3nergy
    Dark~3nergy what was dat sandvich ?
    14 Jan 2007
    Damn, that is a sweet looking case and those tubes look really great ! you should use chromed copper pipes for the rest of the build instead of normal plastic hoses.
  19. stonedsurd
    11 Mar 2009
    Love the plumbing. Now I want to see the wiring. I've been bouncing around a lot, and lurking more than I should. I'll try and be more active now :thumb:
  20. The boy 4rm oz
    10 Apr 2008
    Stunning work as always Attila! Just wondering, have you considered doing the entire loop as hardlined nickel plated copper pipe?
