DarkWater SpaceShip - First Prize winner!!
Discussion in 'Project Logs' started by Kumo, 10 May 2005.
  1. bootupbuddha
    bootupbuddha grunge modder
    3 Feb 2004
    Spainish modders unite! :rock: - well I am 1/2 spainish anyway. great mod Kumo, I just came across it. I have been wanting to do a w/c shuttle. I'll watch yours instead.
  2. Kumo
    Kumo What's a Dremel?
    18 Oct 2004
    Today update, resume the button works
    The chrome plastic frame glued over the nut.
    The cap on position... Perfect match.
    Rear view.
    The decorative rez
    Two plastic lights covers from the Antec Sonata front...
    Glued together...
    And glued again, in the front
    An overall look while drying.
    Making the loop
    Testing the first tubing. A short piece from the pump to block, reinforced with coolsleeves to avoid excesive bending.
    More tomorrow!
    @bootupbuddha: half spanish better neither hehehe. I supouse your father is Spanish, isn't?
  3. Kumo
    18 Oct 2004
    Few work yesterday...
    More tubing in the loop. The GPU.
    Painted and finished chasis with the tubes in the GPU block.
    The tubes fits well. Maybe, some Coolsleeves more is needed, i`ll see it later.
    The tubes pass pretty close of the DVD.
  4. jopers1986
    jopers1986 Minimodder
    7 Jan 2005
    1/2" in a shuttle :eeek: not gonna be much flex in those tubes! hope it doesn't put to much strain on the blocks and barbs!
  5. Kumo
    18 Oct 2004
    1/2" but OD. Still left some tubing more... i'm planning how to.
    I tried 1/2" ID tubing but was too much with that config. To use 1/2" IDtubing, need to replace the full DVD for a slim one and change the VGA block or its barbs for more apropiates ones and other works.
  6. Kumo
    18 Oct 2004
    More updates in the loop works.
    Short pieces of CoolSleeves on the GPU tubing.
    The fan i`ll use until i get a 80x38mm better fan. A trust YS-Tech fan of 3/3.5K RPMs
    The sleeved fan. Note the black three pins connectors to replace the white ones.
    Black painted clamps.
    The mounted BLIM rad...
    ...With the tubing
    More tomorrow!
  7. koola
    koola Minimodder
    11 Jul 2004
    Nice mod, looks like it's gonna be real tight!
  8. Kumo
    18 Oct 2004
    At the output of the rad will be a "Y" to the pump and the Fillport. No rez this time.
    I have to see how i put he fillport in the hull modifications.
  9. (spc)kuhnkejer
    (spc)kuhnkejer What's a Dremel?
    14 Feb 2005
    nice work. cant wait to see what temps you end up getting.
  10. richman
    richman What's a Dremel?
    17 Sep 2003
    Hiya, Good work their man what process did u have to take to paint the main chassi?
    I wanna paint my shuttle's chassi but i wanna make sure it dosent flake, did u prime it or anything before hand.
    Cheers
    Rich
  11. Kumo
    18 Oct 2004
    This time i didn`t use primer. First i sanded che chasis and then applied several coats of Duplicolor black mate paint for plastics (no need primer). When all coats are dry (very quickly with this paint), applied at least, 2 coats or more of Duplicolor Bi-Coat lacquer.
    Its a paint usually sold for cars and others works that need good finnishing.
  12. Kumo
    18 Oct 2004
    Updates!!
    Finishing the loop: Rad - Y - Pump.
    With the pump mounted in the cage.
    And the DD Fillport. One day i made a guide to copy this thing (lot of maney saved) and use in my LanMachineInterface mod, but this time i decided to buy one.
    Filling and testing. Mix of distilled water and anti-freeze. Only the pump has been powered for the test.
    The first runnings with lots of bubbles...
    Then, running smoothly without air in the loop. The pump is almost totally silent with the case open.
    No leaks, as well :)
    A little preview of the work to come... markings and cuttings:
    Stay tunned!
  13. kaotic504
    kaotic504 What's a Dremel?
    20 Jul 2004
    that's pretty nice man, great work.
  14. advance
    advance What's a Dremel?
    18 Apr 2005
    I'm gonna have to keep my eye on this one.. Subscribing now.
  15. cool_dude
    cool_dude Minimodder
    26 Aug 2004
    luks real good! shame the 939 shuttles are expensive otherwise i'd have done that.
    kickass! :)
  16. Kumo
    18 Oct 2004
    Thanks for the coments.
    Yes the 939 are still expensive around at least 100euro more than this.
  17. luvbug
    luvbug What's a Dremel?
    22 Sep 2003
    Hmm... all I see is:
    op_stop(); ;op_start();
    Stay tunned!
    What gives? I was just about to comment on how I dislike project logs with links to pics instead of actual pics... but I don't think that's the case here...lol. Is something messed up on my end or yours?
    luvbug
  18. Kumo
    18 Oct 2004
    I have no problems with the pics. Anyone more view only that text?
  19. QuinnDexter
    QuinnDexter What's a Dremel?
    28 Feb 2005
    fine for me tooo
    lookin good btw
  20. luvbug
    22 Sep 2003
    I checked your other project log and it's the same thing with the pics. About half of the pics show up for me, the other half are that text. Weird... All other pics in other project logs show up fine, just yours are the ones I'm seeing this way.
    luvbug
    EDIT:
    The text is a hyperlink to http://www.imageshack.us/ and nothing else. Never run into this problem before, someone let me know if I'm the only one seeing this.
    Thanks,
    luvbug
