Scratch Build – In Progress Megablaster 2010 work log (diy ghettoblaster)
Discussion in 'Project Logs' started by drakmin, 14 Mar 2010.
  1. gcds
    gcds What's a Dremel?
    22 Nov 2006
  2. deadlyavenger
    deadlyavenger What's a Dremel?
    6 May 2010
    Wow - that thing looks awesome! Nice work.
  3. drakmin
    drakmin I don't use Dremel.
    20 May 2006
  4. gcds
    22 Nov 2006
    Nice, but i think so acrylic is not practical to use in portable operations because scratches and everything else could happen. And you could put better connector for input that bananas looks crazy in this thing i suggest you 6.3mm jack with glowing red border :pP that would look delicious ;)
  5. drakmin
    20 May 2006
    True. This is mainly done for the looks and as a hobby, not sure if it will be ever used :D I have more practical ghettoblaster models which are designed practicality in mind. I might change the banana connectors though. They were the most durable connectors I had in my storage at the moment. I hate rca and 3,5mm plugs! :] 6,5mm might work thanks for the tip.
  6. gcds
    22 Nov 2006
    In your situation 6.3mm will be best and i suggest to make from acrylic ring red light like border on bulgin switches it would look cool :rock:
  7. drakmin
    20 May 2006
    Here's all whats needed for line level 6db/oct @ 70hz high pass filter. At the moment I placed the filter inside the line in cable but I'll move it into the blaster at the same time I'll add voltage meters and new connectors.
  8. drakmin
    20 May 2006
    Two possible placements for the voltage meters. First version has the glowin line input. Second version has yet unsolved input placement.
  9. stonedsurd
    11 Mar 2009
    I prefer v2. The first one sort of ruins the sleek lines.
  10. The boy 4rm oz
    10 Apr 2008
    Definitely placement 2.
  11. Jipa
    5 Feb 2004
    I'll probably need to hate you to death if you make the v1 bulge.
    Also an XLR connector might work.
  12. Throbbi
    Throbbi What's a Dremel?
    10 Sep 2009
    Jealous much!! I don't want one....I NEED ONE!!! Seriously cool work there. :D
    P.S. With it having rather alot of bass power may i recommend testin with 'The Perfect Drug' by Nine Inch Nails. I appreciate not everyone's music tastes are thhe same and this, of course, may not be to yours but it does have some freakishly powerful subtones thrown in and will give you a real test of how i copes with the bottom end of the Hz spectrum. Just a thought :)
  13. drakmin
    20 May 2006
    Thanks for the opinions!
    Casualties of the first day in use. Epoxy failed. Replacing with contact glue.
  14. The boy 4rm oz
    10 Apr 2008
    Contact adhesive is great stuff, a very strong bond, I found it works better than epoxy for large areas.
  15. Picarro
    Picarro What's a Dremel?
    9 Jun 2009
    Much love on the speakers, and yes contact adhesive glue works wonders.
    Btw, sent you a PM, would be nice if you could answer my questions :)
  16. drakmin
    20 May 2006
    Picarro: thanks for your questions :D
    Finally got the voltage meters:
  17. big F
    big F What's a Dremel?
    1 Feb 2010
    theres somthing about dead smooth acrylic mmmm! even more when its black. :)
  18. Burnout21
    Burnout21 Mmmm biscuits
    9 Sep 2005
  19. DeafGamer2015
    DeafGamer2015 Minimodder
    5 Jun 2010
    Any update in this? Also sorry about the thread revival! I just hate to see unfinished project logs.. :( :waah:
  20. drakmin
    20 May 2006
    This has been in use for years now and I finally managed to make a really really compact "log" with 2 gif's. In the end I didn't add any voltage displays.
    http://imgur.com/gallery/7dz6j
    -worklog finished, thanks a lot for reading!-
