Miranda™ Feedback Lian Li PC-6070 The projekt will only contain smal configurations, forming plxi and other things that makes the case look better. Coolermastern is offline for now.. The satisfaction is hight at this moment (the habit has cougth me with handbars again , since its pritty serious.. ) Orginal Front: This button from ELFA (35-072-25) and have a built in diod *bling* *bling*. (Red) Power, Reset. Coolermaster, Wavemaster Black This case shall be returned couse the differense on what you get for your bucks differs quite a bit between the two cases. I were going to put a fanbus inside the case between the external contacts. Snice the Coolermaster dosnt have a removal HDD tray like the PC-6070, its more practikal solutions on the PC-6070 for me. And the functions on the Coolermaster are few compared with the PC-6070. Then again its ofcourse my taste, and I dont balme Coolermaster users, its still a great looking case. But I think I would tired a bit faster with the Coolermaster.. ThermalRight XP-90C (600g) Cooling updates it whont be many of, but I bought a XP-90C (c for copper).
Feedback Sleavning of ATA & SATA © Have since a long time back looked for ATA and SATA cabels wiht cabelsocks and so forth, but since no one in the industrie makes these exept some few in the states, I hade to make some of my own.. ATA Socked / Orginal (plastic) SATA Whats needed: (Everything is from ELFA) : ATA Shrinkhose, 55-073-06 Cablesocks, 55-057-22 SATA Shrinkhose, 55-071-08 Cablesocks, 55-057-14 The Results The result was over my expectation and one step closer to the habits end..
Feedback Polishing NEC 2500 DVD RW Before / After Whats needed: Wet sandpaper 800, 1200, 2000 Nice pease of taul and Autosol Was it worth it? a whole day and a heck of energi.. the answer is yes. Since you are so depth inside this ****, everything you do that makes the thing look even better and shiny, worth every bit of strength. But wait, ist Insane! The DVD whont even matter couse you will not see it benith the alu steel around the 5.25 places..
Feedback Crucial Ballistix Tracer Since the comuter whont be a benching-rigg, or will it? , with that cleard it was time to get two "normal" 1GB moduls Crucial Ballistix Tracer (with some disco leds on the topp witch realy isnt my tast). But in overclocking Iv heard quite a about this pair. Worked some with bios 5.10 XCEL2-LL to the DFI Ultra-D board. But the sticks wouldent go abow 250 3-3-5-3. Iv now tried Oskars later version. 704-2BT. Will try to reach atleast 280 with 2.7-2.9V And it whent better than I would have hoped, its quite amazing it can differ so much with the latest bios: And if I understand right, its possible to reach higher clocks with the right Tref TREF 15.6 7.8 3.9 1.95 FSB values for a TREF value 1552 99.5 199 398 796 2064 132 265 529 1058 2592 166 332 665 1329 3120 200 400 800 1600 3632 233 466 931 1863 4128 265 529 1058 4672 299.5 599 1032 66 132 265 1296 83 166 332 1560 100 200 400 1816 116 233 466 2336 150 299.5 599 1168 75 150 299.5 1536 98.5 197 394 2048 131 263 525 2560 164 328 656 3072 197 394 3684 236 472 4196 269 538 4708 302 Länk Did it work? Before with Tref 2560: And after with 1032: Reached my goal 295FSB. Thou its not entierly stable in more demanding aplications, but with driving win and PS/Premiere and so on, it couldnt nearly reach win before this Tref value no mater witch voltage.. So try different Tref values untill you find the best one for you.
Feedback GTO² Got an anxious need of a need video card so I orderd a Sapphire GTO² from UK in thursday evening. Well, it weights! Either the cooler is made out of steel, or its the havies card I own. (Its steel ) Lets see if there will be any 16 pipelines instead of 12.. If you understand Swedish, dont look at the book Took the clothes of my card to see if ther were any 1.6ns memmorys etc, witch it were. And a 480 core. Nice when something makes sence.. GC16
Feedback Test with the Fanbus, couse it will be moved a bit from the front couse I wasnt sure if the screws would fit. Well it did with hair.
Feedback Project starts for real! [2005-11-04] Finaly! Iv just started the actual build, and Im so happy after just one good and demanding modding day. Im going to introduce a friend. Everything is done manualy etc, so no CNC-machine here, witch you are a bit proud of . Its quite stimulating to get the precise measure that the machine requires for a good result. Anyone know what this is caled? Anyway, a bottom of a used printer. Something that would be the steel peace that I would work with, but uneasy to work with, so it became a 1mm steal from ClasOhlson
Feedback continued.. SLK 948 Über Hade in mind to rebuild a SLK 948U to a effective air cooler, with a shroud and a Delta 60mm, witch hopefully would give the GTO² something to put its teath in. Its not finiched yet as you can see, but will be in a near future Before / After
Feedback continued.. Steelwork At different places in the case, there will be steel peases abow the plexi bits as an effect, then will shine under the steelpease, and hopefully it will look good. Sandpaper can feel its destruction. Think this machine with 1000-2000 nice paper, great surfaces..
Feedback continued.. Power / Reset This will be the new switches with will be fitted on the PC-6070 case. Red is the color, but the plexi that will be in the front will be darkblue, so lets hope thwy will fitt togehter. Was it worth? Ooo yeah, havent feelt this releaved feeling then after a 5h heard work, witch showed some results. The habit (modding/computers) are near to explode, but its cool. But my girlfriend, this anit good for the relation or the mind on me. Dont know how much you think of it, but my little grey mass of brain has modding/computers more in the head than sex! Just as an expression, but beneth al deskussions I have the computer lies beneth and steals atention. Well well, todays work results. . A taste of the color the plexi will have. Night! ________________________________________________zZZzzZZzz (This was yesterday eve )
Feedback continued.. I tried the SLK über in place. Togehter with Revoltecs copper cooling. As I said the shroud isnt done, it will have to be more open and pollished or sprayed More will come!
Feedback :: Miranda™ Feedback :: Miranda™ Discussion around the project Miranda™ The project Updates Sleaving of ATA och SATA [2005-09-25] Pollishing of NEC DVD RW [2005-09-25] Crucial Ballistix Tracer 2GB kit, OC test.[2005-10-04] Sapphire GTO² arives, flasing of bios and OC.[2005-10-10] Fanbus, pollishing etc.[2005-10-20] Worklog, project starts for real [2005-11-04] (Five posts long) Pollishing the GPU shroud.[2005-11-08] Project :: continues! Acrylics arrives. [2005-12-31] (Three posts long) Workshop :: Update! [2006-01-02] Workshop :: Last but not! [2006-01-04] Update :: I'm Back [2006-07-25] Day 2 :: What's it say? [2006-07-26] (Two posts long) Day 3 :: Chemical metal? [2006-07-27] Day 4 :: Endphase one [2006-07-28] The project More will be done in xxxday. Hope everyone will like it
Feedback Fanbus Before / After Another evening whent past. The fanbus are made of a Sunbeam Rheobus and black alu weels from ELFA. The thought was to put a plexi pease, blue color, ontop on the fanbus, witch will have another fanbus abow. So there will be two abow eatchother. Was it worth, I wouldnt recomend to jame / stuck in this ****. More later on...
Nice very nice... But, as you stated at the bottom of the last post, the shroud has to be more "open"... There's no way the (hot) air can get out of the heatsink/shroud. Lot's of succes on the rest of the project
Maybe better to use some perforated alu for your shroud. Maybe meshX or something. It's also better to bent so it will be much neater. Because that shroud sucks. The rest of your work seems pretty fine! Succes!
Well its not nearly finished. Hope you can understand that But please come and critizise and bring ideas up
Good start... curious as to what it's going to look like in the end... Especially with the newest case...
