Miranda™
Discussion in 'Project Logs' started by Razor_cut, 6 Nov 2005.
  1. Razor_cut
    Razor_cut What's a Dremel?
    12 Mar 2004
    Not shure what you are saying..
    Since cold air is coming on the gpu form the case door, and cold air on the cpu. I dont see how it could go bad..
    And when the shroud have been remade ->
  2. Firehed
    15 Feb 2004
    If you modify the shroud like indicated in that last picture, it should be fine. They were concerned that the shroud would cover up any place the heat from the GPU could escape from.
    Very cool project anyways, I'll be keeping an eye on it!
  3. zr_ox
    zr_ox Whooolapoook
    5 Jan 2005
    Nice fabrication...Its looking really good.
    One thing though, I like the look of the shroud but I think its use will have a very limited effect unless you are feeding it with cool air from the outside (using side intake).
    The way I see this is that the shroud will be in effect reducing the amount of air getting to the gpu. Air coming from the front intake will not be passing over the gpu as it would without the shroud.
    I could be way off but it looks like your choking the air supply.
    Keep up the good work though.
  4. Shadowed_fury
    Shadowed_fury Minimodder
    21 Nov 2003
    Very nice looking work :) Keep it up!
  5. Razor_cut
    12 Mar 2004
    Iv thought of that, It will be two side fans, one for the direction on the gpu and the other for the cpu..
    Then the case have one! fan to bring the hot air out, but there will be one other modded beneath that. So with two fans with reasent flow, I hope it will circle :worried:
    Thanks for the feedback all!
  6. Razor_cut
    12 Mar 2004
    Feedback
    Polishing
    Polished the shroud a bit under the night.
    • [​IMG]
    Someting tells med that this would help and make the job a bit more easy..
    Enjoy!
    :thumb:
    Teaser..
    • [​IMG]
  7. Razor_cut
    12 Mar 2004
    A little update on the shroud this evening..
    Have a go..
  8. Razor_cut
    12 Mar 2004
    Did some sketches, for a sort of memmoryshroud. Do you think it will work out?
    Or just be a bad effect?
    • [​IMG]
    Thanks :thumb:
  9. Razor_cut
    12 Mar 2004
    Then, made a sketch over a memmoryshroud.
    Have a go.
  10. 731|\|37
    731|\|37 ESD Engineer in Training
    5 Sep 2004
    im thinking that your just going to heat your mem with the excess are comming off the GPU. Either kill the shroud or vent the GPU air somewhere else and provide more airflow through the shroud
  11. Zds
    Zds What's a Dremel?
    3 Nov 2005
    This was very well worth the trouble. What was the magic substance in addition to mad mod skillz and sandpaper that gave you this good result? :eek:
  12. Razor_cut
    12 Mar 2004
    Just wet sandpaper. Start with 800grid, 1200 and finaly 2000. You will then have a nearly mirror finnish. But after som Autosol, you surely got it!
  13. Zds
    3 Nov 2005
    Ok, gotta give it a try :). This Autosol is some kind of polishing substance meant for cars?
  14. Razor_cut
    12 Mar 2004
    Some plaiting with the Delta wires..
    • [​IMG]
      Love this process, when you shrink the wire/hose.
  15. Razor_cut
    12 Mar 2004
    Thats right.
    Did some plaiting with the wire coming from my Delta 80mm.
    Have a look :thumb:
  16. silent_project
    silent_project What's a Dremel?
    10 Aug 2005
    looking good, so long as the air finds a way out!
  17. Razor_cut
    12 Mar 2004
    Feedback
    Project :: continued [2005-12-31]
    • Acrylic
      Blue bottom, for making a reflecting effect of some sort, and ofcourse the outlook. :thumb:
      Holes for the wheels, as you can see at the abow pictures..
      Exelent tool to remow iron thats becomed after the drilling..
  18. Razor_cut
    12 Mar 2004
    • Feedback
      continued..
      In the trace of Lian Li
      Remember this peace?
      Being tried out, so the machine whont destroy the acrylics..
      Result :)
  19. Razor_cut
    12 Mar 2004
    • Feedback
      continued..
      Mounted
      Teaser ~ Not much but something :thumb:
  20. Big SturL
    Big SturL What's a Dremel?
    15 Jul 2005
    Ahh, I truly love your case. Us Scandinavians really have a sense of style :D But, why didn't you buy the SCAND version? The so called Scandianavian version, where there are one 120mm fan in the front and the back rather than 3 80mm.
