Miranda™
Discussion in 'Project Logs' started by Razor_cut, 6 Nov 2005.
  1. Razor_cut
    Razor_cut What's a Dremel?
    12 Mar 2004
    Updates!
    After some diseases and moving outside the town the continue is a fact!
    Have a look.
    All pictures come in 600x450 /450x600 resolution.
    The compete thredd.
  2. gar
    gar Minimodder
    15 Sep 2004
    Are you going to have room for a sound card, or anything after you've fitted your video card. How will it all fit in there.
    10/10 Fair play for allday polishing. It looks class!
  3. Razor_cut
    12 Mar 2004
    Well a PCI soundcard could be possible, but not shure if I need one.
    :thumb:
  4. Altron
    Altron Minimodder
    12 Dec 2002
    For the RAM heatsink shroud, IMO it would work if you rotated two of the heatsinks so that the fins were perpendicular to the shroud/GPU fan.
    so like
    Code:
    |------------------|             ____
    |--HEATSINK------|              ____
    That way, the air coming out of the shroud flows through the RAMsinks. I think in your picture, two of them were pointed the wrong direction, so the air would hit them and stop.
  5. Razor_cut
    12 Mar 2004
    Correct Altron, will do turn the heatsinks, from the beginning it was ment to be just one fan, and in that case the sinks would have to be in the airs direction.. But now with three fans its a different story,
    Thanks!
  6. DaLoonie
    DaLoonie What's a Dremel?
    2 Aug 2005
    Looking good there. I though have a little suggestion to the Lian-Li styled side drive holder.
    How about adding to LED's to either side of it. Maybe from lowest corners pointing to the middle? Would make a great effect ;)
  7. God_Of_Death
    God_Of_Death What's a Dremel?
    13 Feb 2004
    Miranda™
    is this related to Serenity?
  8. Razor_cut
    12 Mar 2004
    Feedback
    Workshop :: Updates! [2006-01-02]
    Continued my work to an absolute end of my addiction : :idea:
    • HDD racket (2nd side)
  9. Razor_cut
    12 Mar 2004
    • Feedback
      continued..
      A never ending mistake!
      To be continued..
  10. Razor_cut
    12 Mar 2004
    • Feedback
      continued..
      Power nr: 2 [extern]
      Powerbutton at the front, for comfort and outlook :thumb:
      Do never work under stress!
      Some outsides..
    Untill next :cooldude:
    Good one!
  11. Razor_cut
    12 Mar 2004
    • Workshop :: Last but not! [2006-01-04]
      Another hectick round, for the fron grill and other parts of the case..
      Formatering of the case
  12. Razor_cut
    12 Mar 2004
    • Feedback
  13. Razor_cut
    12 Mar 2004
    • Feedback
      continued..
      Grill on!
      This picture shows how messy as x!#*Ell I grinded the grill. Fortunately it will be fixed next time!
      Some fronts..
      [​IMG] [​IMG]
    A long brake will now come.
    But I will soon be back at the late of February.
    Until then.
    Have a good one!
    See ya!
  14. Razor_cut
    12 Mar 2004
    • Feedback
      continued..
      Grill on!
      Some fronts..
      [​IMG] [​IMG]
    Until then.
    Have a good one!
    See ya!
  15. Razor_cut
    12 Mar 2004
    Updates!
    [2006-01-02]
    [2006-01-04]
    Hope you like it!
  16. Razor_cut
    12 Mar 2004
    Nope, its my name after a child.
  17. koegsmk
    koegsmk What's a Dremel?
    31 Aug 2004
    I must say this is beautiful.
    The setup reminds me of something i have done before... :rock:
  18. koegsmk
    31 Aug 2004
    I have got the same case, the same ideas, the same RAM, same board.
    This is frightening. :worried:
    I am happy to say that now i am using a modded Apple G4 case as the new home for my computer. :dremel:
  19. Razor_cut
    12 Mar 2004
    Very nice! looks very much like eachother :thumb:
    Hope its feels okey :)
  20. JAxen
    JAxen What's a Dremel?
    18 Nov 2005
    I really like it when I see that Miranda worklogg has been updated :)
    Have fun in South Africa ;)
