Miranda™
Discussion in 'Project Logs' started by Razor_cut, 6 Nov 2005.
  1. Razor_cut
    Razor_cut What's a Dremel?
    12 Mar 2004
    Hey, thanks!
    Will be fun to keep posting for you people :thumb:
  2. Wolfe
    Wolfe What's a Dremel?
    7 Sep 2003
    I am sooooo jealous of your metal working shop, especially the mill.
    Are you using an online translation service to write your posts?
  3. Razor_cut
    12 Mar 2004
    Update [2006-07-25]
    Older, put on some weight and maybe a bit unfocused.
    But here’s a four days period of work.
    • [​IMG]
      Back again.
      Unpacking
      The bad quality of the steel has become a bit rusty after some worm weeks
      up here in Sweden.
      Making another front bezel for the second fan bus which should be in place shortly.
      Preparation of the frontpanel
      Some grill which are supposed to cover the hols for the fans. Had some problems trying to bend them.
      [​IMG] [​IMG]
      And the frontpanel which are supposed to have three air intakes has been redone from planning. The previous thought:
      __________
      __________
      __________
      Made some bad tightening of the panel and the mill got some to the left and nearly messed up the whole front. But it's a minor ****'up from me.
      Bye
  4. Razor_cut
    12 Mar 2004
    Day 2 :: Are u talking to me? [2006-07-26]
    • [​IMG] [​IMG]
      Just whana present a new friend, a Manfrotto stabilizer for the camera.
      Better fancontacts?
      Become quite okey, but the cables are awsome.. :thumb:
      Away with oldies
      New fronpanel for Power, Reset, HDD light och Power light.
      DThis time with blue plexi in the background.. :thumb:
      [​IMG] [​IMG]
      [​IMG] [​IMG]
      [​IMG] [​IMG]
      Hopefully the complete work will hold the same standard. :thumb:
  5. Razor_cut
    12 Mar 2004
    • [​IMG]
      Better fancontacts?
      Away with oldies
  6. Razor_cut
    12 Mar 2004
    • continued...
      On the front we goo.
      Made a form so there whont be so hard to make the right form of the grill in the front.
      This day worked out pritty fine, got one point from the planing removed which feels great.
      Whats this?
  7. Razor_cut
    12 Mar 2004
    Day 3 :: Chemical metal [2006-07-27]
    • [​IMG]
      I LOVE THIS MACHINE!
      Pads which should be between the wheel and the plexi.
      Long time no seen
      Pretty fun to hit the grill into different shapes..
      Hopefully will look more attractive in the future...
  8. Razor_cut
    12 Mar 2004
    Day 4 :: Endphase one? [2006-07-28]
    • The previous shroud for the GFX card would be to complicate to workout, so a new maybe easier one is beeing made.
      Hit hard
      Hopefully it will look nice with some black color later.. :thumb:
      That is alles.
  9. Klekkus
    Klekkus What's a Dremel?
    5 Nov 2005
    Sweet, I want a CNC too! Good job on the mountingplate too the switches ;)
    Edit: You posted the same update in two posts ;)
  10. Razor_cut
    12 Mar 2004
    Noticed, but I can't remove that. A moderator must remove it.
    Thanks!
  11. Klekkus
    5 Nov 2005
    Damn, that's some hot acrylic!!!
    (OT: Jeg trode først at det sto mona lisa på den boka de, bra bok?)
  12. Razor_cut
    12 Mar 2004
    You meen the color? well dark blue is my favorite.
    And most likely on of the most usual ones.
    Cherio
  13. Klekkus
    5 Nov 2005
    Yes, and when the edges are plished it looks sweet.
  14. hydro_electric_655
    hydro_electric_655 Dremelly Dude
    13 Jul 2006
    Why did you mutilate the nice even fins on the GPU heatisnk? Looks really sweet though. I love the front panel and your manual mill
  15. scifi3018
    scifi3018 Minimodder
    6 Feb 2005
    Wow, i was reading this through, and wondering what in the world you were going to need all that fan-controller-age for, but this case is going to packed with fans.
    3-4 fans for the graphics card alone... incredible
    Keep up the fantastic work :thumb:
  16. Razor_cut
    12 Mar 2004
    Thanks, a bit noisy maybe, but hopfully with the fancontrollers it will be controlled and well circulated.
    The gpu heatsink was to high and a bit lowerd so it will fit. One or maybe two PCI cards will be underneath.
    Thanks!
  17. Razor_cut
    12 Mar 2004
    OCZ - Seasonic 600W :: ONE [2006-08-31]
    • [​IMG]
      OCZ Powerstream 520W
      Seasonic 600W
      Now added the two OCZ cables to the Seasonic.
      Edit:
  18. Razor_cut
    12 Mar 2004
    Sleaving [2006-09-04]
    • [​IMG]
      :thumb:
  19. Razor_cut
    12 Mar 2004
    Intel Core E6600 + P5W [2006-09-03]
    • [​IMG]
      :thumb:
      Some smal updates, wish to bring some more, but not untill thursday for that :)
  20. Guest-23315
    Guest-23315 Guest
    yay finally an update !!
