Miranda™
Discussion in 'Project Logs' started by Razor_cut, 6 Nov 2005.
  1. customh
    customh conflagration.
    22 Oct 2005
    B-E-A-U-T-I-F-U-L
  2. Razor_cut
    Razor_cut What's a Dremel?
    12 Mar 2004
    Sandpaper: 800, 1200, 2000. (start with the 800. But even better
    is to sweep the whole area with 200grid or so at first. the the
    following rout. But be shure to move back and forth, back and forth etc.)
    Yes I haven't polished the acrylic, but will do later.
    Thanks for the remider thou. :thumb:
    Thanks for the positive feedback!
  3. Denied
    Denied What's a Dremel?
    28 Oct 2005
    That looks really really good... are you going to treat the finished surface though? Autosol is great for making things shine but that will go tarnished and rusty if you don't at least put some wax on it (similar to when you polish your car)
  4. Razor_cut
    12 Mar 2004
    Will spray it with Protection clear lacquer, clear
    spray witch will hold the clear surface I hope..
  5. Razor_cut
    12 Mar 2004
    • I grinded the sides of the acrylic plates.
      But theres nothing called perfect here..
      Plain and shiny.
      How it looked erlier. Some difference..
    :thumb:
  6. Fozzy
    Fozzy What's a Dremel?
    25 Jan 2005
    I think you should put the acryllic plates on the outside. Would look better IMO
  7. ReFredzRate
    ReFredzRate Relix Headshot!!
    2 Sep 2002
    Imo, the acrylic plates look great where they are now, only, they should be lit up.
  8. Denied
    28 Oct 2005
    I have to agree with fredz too, this way it's nice and understated.
    Looking really good, those edges came up a treat!
  9. Guest-2867
    Guest-2867 Guest
    yeah just mount a few LEDs in the bottom of the acrylic, it'll look amazing if you hide the wiring well
  10. Razor_cut
    12 Mar 2004
    You just laid the planing open for the webb. :thumb:
    But we will see when theres time to continue.
    But there will be four LEDs on the plate with
    9 holes and possibly two on the other side...
    Thanks!
    • The surface on the metall has been sprayed with "anti rust" or something. It looks more like glas now :)
      Not so well pollished but this side will not be seen in the case.
  11. Klekkus
    Klekkus What's a Dremel?
    5 Nov 2005
    Nice, after some more sanding and polishing it looks much better!
  12. foundsoul
    foundsoul What's a Dremel?
    24 Aug 2004
    May i ask is this really needed?
  13. hydro_electric_655
    hydro_electric_655 Dremelly Dude
    13 Jul 2006
    I don't particularily like the HSF unit but the idea is nice. The execution...could use some work.
  14. Razor_cut
    12 Mar 2004
    It will be used untill the GPU block arives...
    Since the work was made mostly on the fact of outlook, estetics etc. I didn't think of air pressure.
    The blue dots are nipples from the radiator (PA120.2).
    Soon another update.
  15. Razor_cut
    12 Mar 2004
    eVGA 680i
    :: eVGA 8800GTS :: PC-V1100B :: Mushkin XP2-5300
    pix
    The orginal modification, Miranda, is short out of work. I mean time this is the comp I setled for.
    Love this nVIDIA cooler, togehter with the RAM it's nice.
    The motherboard is compleatly in my taste, simple and clean.
    :thumb:
  16. customh
    22 Oct 2005
  17. Jipa
    5 Feb 2004
    Damn sexy hardware :)
  18. JAxen
    JAxen What's a Dremel?
    18 Nov 2005
    Nice to see that your still alive n' kickin =D
    And yes, damn sessy hardware..
  19. RonaldoR9
    RonaldoR9 What's a Dremel?
    17 Dec 2006
    lol is this thread still alivee
    btw i love that board evga is sickk plus them mushkin ram amazing
    ccan u post pics overall of the board not zoomed in i wanan buy that ram and board buy i wanna see if that green pcb ram is taking away from the 'black' look of the board
  20. Thorn
    Thorn Gaijin Studios
    19 Feb 2004
    Project dead ? hmm or still alive ?
