Case Mod - In Progress Neptune's Trident: Wallpapers
Discussion in 'Project Logs' started by Boddaker, 31 Dec 2008.
  1. Attila
    Attila still thinking....
    22 Feb 2008
    Yep! That's the one. :thumb:
  2. Reverse
    Reverse Reverse/srvR
    25 Sep 2008
    looking way better!
  3. Spyrious
    Spyrious Modding all the Time
    8 Dec 2008
    Beautiful.I think whatever changes you make you just make the excellent better.I'm amazed by the water tank.
  4. craigbru
    craigbru Cramming big things in small boxes since 2006
    28 Feb 2008
    Perfect, just perfect. It does fit so much better. :thumb:
  5. Jozo
    Jozo This is bit-tech
    14 Mar 2009
    Fits perfect and is in pair with the window. :thumb:
  6. dark4181
    dark4181 Ero-sennin-tebayo
    3 Jan 2008
    Looks great!
  7. Boddaker
    Boddaker Still hangin around
    30 Nov 2006
    Thanks all. :) It finally "feels" right. We're super close now! Now I'm toying with turning the trident around so the three prongs point up towards the reservoirs. The bottom would still wrap under the case, and it would match the way I cut the mesh boxes. I'm just not sure how well it would cover the fan area then.
  8. jhanlon303
    7 Sep 2006
    It is nicer this way. Sometimes simpler is better. Good looking.
    john
  9. The boy 4rm oz
    10 Apr 2008
    Sweet work as always Bod, your designs and execution are very good.
  10. Boddaker
    30 Nov 2006
    Got some actual work done on the front! :D Was so anxious to start working on it, I neglected to take
    pics of the cutting. But that's just basic stuff anyways... measure, mark, measure, cut.
    After cutting and filing the edges, I proceeded to bend the bottom tips of the trident. Looking around the garage
    for a suitable object to bend around, I spotted the post of my drill press, and saw how easy it was to dismantle lol.
    Moments later, I had it in the vise and beating the trident into submission.
    The result. The surface is a bit weathered, but it's nothing a good sanding won't cure. I'm just focusing on the
    smooth curve for now.
    Positioning it onto the case it looks to be about right. This will give me about a 1/2" space between
    the trident and the mesh.
    So I marked some holes and drilled them out.
    Screwed it right into the mesh.
    I removed it again and cut the top off level with the bottom of the drive bays, then drilled a 3/4" hole
    for the power button. After a good sanding and clean-up, it looks like this:
    I will be adding a piece of blue transparent acrylic behind the trident as well as a short tube to cover the
    back side of the switch. Also have to drill some small holes to accommodate the pwr and hd leds.
    More to come!
  11. stonedsurd
    11 Mar 2009
    Oh my. that looks flippin' wonderful! :jawdrop:
  12. Reverse
    25 Sep 2008
    Looking good so far!
  13. Attila
    22 Feb 2008
    Looks like a bought one! :thumb:
  14. Odin Eidolon
    Odin Eidolon What's a Dremel?
    7 Feb 2009
  15. The boy 4rm oz
    10 Apr 2008
    Front trident really is a work of art.
  16. B4TM4N
    B4TM4N Ninja
    11 Aug 2008
    Holy crap
    Now this is a great mod!
    Maybe you could paint it satin black and murdermod sleave the wires or something?
    Either way i cant wait for this mod to finish!!!
    but dont rush, keep it perfect!
  17. The boy 4rm oz
    10 Apr 2008
    If you look back a few pages you will find that it's going to be painted blue ;).
  18. craigbru
    28 Feb 2008
    Oh, that looks great Brian. You definitely made the right decision to change things up front.
  19. Boddaker
    30 Nov 2006
    Thanks everyone! It's going to look a lot better trust me! :D
    Work continues on the front piece...
    Marked out the location of the front IO ports.
    I started by drilling out the center of the holes,
    Then went in with the rotary tool to trim out towards the lines.
    Finished up with a bit of filing and sanding. Once that was done, I made the mounting holes and screwed in
    the port module for a test fit.
    Next up is the acrylic counterpart. Stay tuned! :)
  20. Spyrious
    8 Dec 2008
    Beautiful.
