Case Mod - In Progress Project: Blue Flames - Case Finish
Discussion in 'Project Logs' started by Nolimited, 24 May 2008.
  1. MarkW7
    MarkW7 Total Noob
    30 Nov 2008
    Nice mod, loving all the updates :)
  2. Tec_
    Tec_ New Member
    26 Feb 2008
    looks very clean, i like it! keep up the good work
  3. ModMinded
    ModMinded Are you throwing that away?
    26 Aug 2008
    Very nice look to it! I really like the jacks passthrough, and the colors! nice cable management as well.
  4. The boy 4rm oz
    10 Apr 2008
    At 80% completion it's looking damn fine.
  5. MarkW7
    MarkW7 Total Noob
    30 Nov 2008
    Any updates ? :D
  6. Nolimited
    Nolimited New Member
    12 May 2008
    Update Cable management
    Thanks @ all for the nice comment :thumb:
    And now update Time :D
    I have find cable that are not sleeve and first finish them and all in black ;)
    First i need to have some cable extensions and need to make it my self.
    When done start sleeving first the cable
    after the power connector again in black :D
    Other cable that need to be done the Usb and FireWire i did only the cable
    Before
    After
    The audio cable for the musketeer same attention cable black
    before
    After
    Also did the same with the temp sensor for the CPU
    Before
    After
    Other cable that are done the cable for the zalman CPU controler
    before
    After
    I check the power cable for the hard disk to long and need to be change
    after the change it will be better ;)
    Start fixing some cables and the CCFL lights.
    the first cables and the first light on the rear of the case
    The second light on the top inside the case
    Mounted the white panel and test with the cables to see who it fit in the case
    An other view
    That's all for today next update soon :thumb:
    Happy modding
  7. The boy 4rm oz
    10 Apr 2008
    Your really getting there. The sleeving is finishing everything off nicely.
  8. Nolimited
    12 May 2008
    Thanks The boy 4rm oz i find also i try to do all the cable but not easy :thumb:
  9. Nolimited
    12 May 2008
    Update CMMusketeer
    Another week-end finish and a small update :thumb:
    I dismounted my CM musketeer because i will add blue transparent add the front of each controller
    This is before i dismounted them :D
    I remove all the cover and also remove the cover from each controller
    I have test with flames but not good :nono:
    I cut the blue transparent on the size of the controller cover
    Here 1 controller cover
    Here a picture from all the covers and the blue transparent
    Other view
    All mounted
    and with the light on
    I finish to mounted all on the case and make a light test.
    other view
    that's for the CM musketeer i love it but other idea are welcome ;)
    I make also a cover for the power supply because to many cables a visible and is not nice ;)
    First take some measure
    and here the piece fixed and in placed
    take another picture to size all
    not so bat and this cutting all done with my Dremel 300 :thumb:
    That's all for this week i will try more next week ;)
    Happy modding :thumb:
  10. Jelle46
    Jelle46 Belgian freedom
    14 Feb 2009
    nice job, btw, I have the same Dremel + workcase (treasure hunt, isn't it). Keep up the good work!!!
  11. Nolimited
    12 May 2008
    @ Jelle46 thanks yes this is the workcase i receive it from my woman :D
  12. MarkW7
    MarkW7 Total Noob
    30 Nov 2008
    Any updates?
  13. Guest-23315
    Guest-23315 Guest
    Looks like its coming together nicely :thumb:
  14. Nolimited
    12 May 2008
    @MarkW7 Sorry for no update because to many work some company has virus outbreak and this take time to solved thanks man
    @Mankz thanks
  15. Nolimited
    12 May 2008
    Back for update
    Sorry fo this slow update but work and other things needs to be done ;-) but lets start the update.
    I have make some modification on the DVD cover because problem when open and close.
    here you can see the modification
    also make soms modification of the harddisk cage because the cable are blocked
    Start remove all disk and check where i need to cut
    Place where the cable need to go before
    remove on the border for better contact off the sata cable after
    The part paint
    Now all insert and test the cables
    Also make fixing system for the Bay cover i use the fixing screw from the motherboard
    Fixed all on the side from the drive bay
    Picture with the cover in placed and fixed.
    I also install the cover beside the motherboard and place all the cable on the right place
    I also finish the cables from the button's
    Now i need to finish all the white covers and when finish i can install all and make some test like the lights and the fan's
    Thanks for reading and happy modding :thumb:
    The boy 4rm oz likes this.
  16. The boy 4rm oz
    10 Apr 2008
    Cable management is simple outstanding, looks very nice.+rep
  17. Nolimited
    12 May 2008
    @ The boy 4rm oz thanks Man :thumb:
    Sorry for this slow update but i am back :thumb:
    i had to order a new harddisk for the data because the other not working like i want
    I have now a 500Gb in sata2
    Install and finish the cables management
    I start finishing the white plexi this take min 2 hours for every plexi to remove all scratch
    This part is to install of the side of the Power supply bay
    Another view
    On the Rear of the motherboard many cables :wallbash: it make my crazy ;)
    A lot of cables not easy to fixed all here you can see it without the plexi
    And here with the plexi install
    Other view
    [​IMG] [​IMG]
    Here a general view from the case :D
    Mounted the grill on the drive bay cover
    Closer
    the rear
    Closer
    I take picture with some light test with the most part install
    The front off the case with the CM Musketeer, Zalman and the Hd leds
    The side view without the lights on only the fan led of the rear fan and top fan
    The top off the case with the fan started
    Other view
    Start the top and the botom leds inside the plexi
    Side view
    the front view with the bottom and top leds on
    And now start the inside CCFL :D
    other view off the case
    Some other picture
    Closer to the windows :D
    Take some other picture
    other view from the window
    The rear view
    The fan from the rear
    And last picture from the lights on
    That's all for today :D and Please vote for me ;) ;)
    jhanlon303 and stonedsurd like this.
  18. The boy 4rm oz
    10 Apr 2008
    This has turned out very well indeed, the paint looks amazing and so does the cable management. Congratz on your MOTM nomination and good luck.
  19. stonedsurd
    11 Mar 2009
    I came across this thanks to the MOTM thread and I am FLOORED.
    Amazing mod, amazing paint, just an amazing job there! :thumb:
  20. jhanlon303
    7 Sep 2006
    I was planning a blue glow like this for my H2O-C7 project. I even tried a few things. Now I have determined that I SUCK! :wallbash::wallbash:
    This is just awesome. very nice balance between the top and the bottom. :clap:
    I'll need to sign a "Do Not Compete" agreement.
    john
    +rep for the effect
