Case Mod - In Progress Project: c-black (Migui 2)
Discussion in 'Project Logs' started by MIGUI, 15 Apr 2009.
  1. DonT-FeaR
    DonT-FeaR I know what a fk'n Dremel is ok.:D
    23 Jul 2008
    wow great result with the grill mate good work
  2. ringo
    ringo What's a Dremel?
    14 Jun 2008
    very good sketches, and a clean work. Stonedsurd is right with his question, while the panel is opened/closed you will get some bending moments on your fan mounting dills, that can be a problem.
  3. MIGUI
    MIGUI What's a Dremel?
    27 Feb 2009
    Hi.
    Well, actually it will not put on the plastic fan, attached to a rod. Sorry for not having explained earlier.
  4. luis_pedro_Sato
    luis_pedro_Sato Minimodder
    29 Nov 2004
    Very strange projet.
    I am saing this in a positiv position
  5. MIGUI
    27 Feb 2009
    Hi.
    Today I did two letters m (aluminium and methacrylate), will be on the front door. The letter will be lit with a red leds.
    Idea.
    The aluminim.
    The methacrylate.
    Then continued with more progress. I have to paint black color of the letter m.
    Regards. :thumb:
  6. perplekks45
    perplekks45 LIKE AN ANIMAL!
    9 May 2004
  7. stonedsurd
    11 Mar 2009
    Looks great!
  8. The boy 4rm oz
    10 Apr 2008
    +1 :D.
  9. MIGUI
    27 Feb 2009
    Thanks for the comments.
    I painted the letter m, lack the paint to dry and then put their assembly.
  10. La carotte d l'o
    La carotte d l'o What's a Dremel?
    27 Nov 2007
    I have subscribed this for time ago and haven't got any notifications. :(
    But i'm really glad that i founded it again, as i said, looks really interesting.:thumb:
    5 stars for me, its top quality so far and i believe it will be top when finished.
  11. MIGUI
    27 Feb 2009
    Well, I've put the letter on the door.
    Regards. :thumb:
  12. grevius
    grevius What's a Dremel?
    17 May 2009
    Hello,
    first, excuse me for me english, is very bad
    this is incredible, it's magnific
    your are a crack with the google sketch up
    Regards
    PD: do you remember me?
  13. haakon.t
    haakon.t :)
    8 Dec 2007
  14. MIGUI
    27 Feb 2009
    Hi grevius.
    Yes, I remember who you are.
    Thank you for continuing the project.
    Regards. :D
  15. perplekks45
    9 May 2004
    What he said.
  16. AnG3L
    AnG3L Ultimate Modder
    19 Mar 2009
    That mod will kick a** once is done! You should give us some lesson on these pneumatic things man! Excellent!!!!
  17. The boy 4rm oz
    10 Apr 2008
    The "m" turned out great. May i suggest frosting the plexi to get a better glow, diffuse the light more you you don't get the blotchy effect on the edges.
  18. MIGUI
    27 Feb 2009
    Thanks for the advice, it's a good idea. I will consider later. :thumb:
  19. The boy 4rm oz
    10 Apr 2008
    You really do get a good effect and it's really easy to do, just a little bit of sand paper and your done.
  20. MIGUI
    27 Feb 2009
    Then you pass the sandpaper to the letter that I made?
