Project -KirKas- Plexi case (Case working and phase one completed!).
Discussion in 'Project Logs' started by marcoboy, 6 Mar 2005.
  1. marcoboy
    marcoboy What's a Dremel?
    5 Mar 2005
    I bought few toslink (optical digital audio) cables from regular HIFI-shop, cut those half, took outer rubber cover off, peeled 3mm from both ends and connected other end to bright leds... :)
  2. Da Dego
    Da Dego Brett Thomas
    17 Aug 2004
    a great idea...Might have to make use of that some time! :)
  3. flapietoetoe
    flapietoetoe What's a Dremel?
    3 Sep 2004
    I especially like the fiberoptics , good idea . but if i were u i would change all lighting to white except ur powerled etc. cause the blue led fan would stand out to much .
    continue like this m8 :rock:
  4. perplekks45
    perplekks45 LIKE AN ANIMAL!
    9 May 2004
    This seems to turn out nicely.
    :~subscribed.
  5. The_Resetter
    The_Resetter I LIKE CAKE!
    6 Oct 2003
    Nice work with the mobo stealth i realy like how it turned out.
  6. marcoboy
    5 Mar 2005
    Thanks you all :)
    I were away yesterday, but today I'm continuing :)
    OS (Linpire Live) running fine!!
    I added three cords with small connectors to cd-rom-drive: One for eject, one for read-led and one for write-led.
    ps. Those crumbs on my carpet are from cutting plexi.... not me eating sloppy ;)
  7. Rufus-Seal
    Rufus-Seal Guest
    I really adore your case:). And you cpu-cooler also looks very nice!
  8. marcoboy
    5 Mar 2005
    Help with paint?!?
    Thanks, that was the cheapest silent cooler I could find ;) And it came with leds witch was plus.
    I'm having REALLY hard time painting the case, or actually handling the plexi after painting it...
    I'm scratching the paint of all the time! And I do try to be carefull, but as my case has lots of those metal cornerbrackets and plexi edges i'm doomed to failure of keeping the paint perfect...
    Any ideas? :wallbash:
  9. greensabbath
    greensabbath Got Wood?
    19 Apr 2005
    possibly put a protective clearcoat over the paint?
  10. marcoboy
    5 Mar 2005
    Case assembeld first time !
    As you can see I put white leds on plexi feets. CD-rom tray cover stil missing.
    ps. those round plexipeaces are there just to keep oll sides even (I have not put all screws in place)
    You can't even see those optical lights when lights are off!! :rock:
    Lights at the moment, starting from top:
    HD activity
    CD read
    CD write
    not in use
    not in use
    not in use
    Power on
    Stand by
    I luuuv the glow plexi gives on bright light.
    Inner fittings are just visible on daylight when power's on. When power's off you can see absolutely nothing inside.
  11. kickarse
    kickarse What's a Dremel?
    6 Oct 2004
    looking amazing!
  12. Rufus-Seal
    Rufus-Seal Guest
    Nooo:( You had to keep the plexiglas clearly, i don't like that white.:'(
  13. Gaoske
    Gaoske What's a Dremel?
    10 May 2005
    Thats some amazing paintwork. Really cool that white look...
  14. marcoboy
    5 Mar 2005
    No no no !! ;) I said "mac-like" ;) so white it shall be!
    I just have some problems with plexifeetlights.... one just turned off :(
    Now I have to wait for few days before anything big will happen with mod. (payday coming...)
  15. jezmck
    jezmck Minimodder
    25 Sep 2003
    if you'd left it clear it's be like every other plexi case.
    i like it as it is!
  16. Bandit_zoraK
    Bandit_zoraK What's a Dremel?
    29 Nov 2004
    Agreed- that is some silky smooth caseage you got there. Awesome.
  17. arkadur
    arkadur What's a Dremel?
    3 May 2005
    dam it's god!
    wow man.. i love it
    what about the other PCI holes?
    by the way - you can use the leds in front for fan activity , or led activity
    you got 5 bays for HDD , you can make more HDD activity (you have it on your MB? )
    you can tell me how you cut the MB cover so good?
  18. marcoboy
    5 Mar 2005
    Thanks all, you are so kind :)
    yeah, I know, i'll have some problems if/when I get some new pci-cards. I just dont want to cut huge holes without use, so dremel should be at hand when aquiring new pci-cards ;)
    I just found the guide how to make independent hd activitylights.... maby few of those. I was thinking about two lan activitylights.... straight from lan connectors?
    I used "dremel" diamondblade to cut the MB cover :) and just time....
  19. arkadur
    3 May 2005
    i know thet you used the dremel for cutting :dremel:
    but how you copy the sketch on the mesh? :jawdrop:
    LAN activity Leds will be great :D
  20. marcoboy
    5 Mar 2005
    oh.. sorry ;) I just placed the mesh over my mobo and looked thru the holes very carefull where to cut :) marked all the right holes with marker and cutted between :) No special tricks, took many hours, but succeed very well :hehe:
