Project -KirKas- Plexi case (Case working and phase one completed!).
Discussion in 'Project Logs' started by marcoboy, 6 Mar 2005.
  1. marcoboy
    marcoboy What's a Dremel?
    5 Mar 2005
    Top panel & panel between HD's and mobo area in place!
    Hi all :)
    I placed the top panel and that panel between HD-area and MOBO-area.
    Now... I didn't measure hd-area's lenght accurate enough. So sadly I wasn't able to fit that aluminium fan INSIDE the hd-area after fitting IDE-cables :(
    And my computer almost got on FIRE today :wallbash: :wallbash: :wallbash: I will be posting pictures of that situation later...
  2. Phaeton
    Phaeton What's a Dremel?
    8 Mar 2005
    I've always wondered what a plexi case painted white on the inside would look like (and i've often considered making one), but now you've answered my question; it looks amazing!
  3. koola
    koola Minimodder
    11 Jul 2004
    Very nice :thumb:
  4. simosaurus
    simosaurus What's a Dremel?
    12 Jun 2005
    the outside of the case looks awesome when its white, kinda like a big block of ice :)
  5. marcoboy
    5 Mar 2005
    Yes it does look like ice :) That's exactly the look i was after, and I am amazed on how it turned out...
    BTW: I'm posting these all posts with that computer ;) So it's operative all the time :rock: (turned off while modding obviously)...
  6. perplekks45
    perplekks45 LIKE AN ANIMAL!
    9 May 2004
    Woohoo... this case rocks. :rock:
    BUT... and yes there is a 'but'... in my opinion you really should change those red LED's on your mobo. I mean all blue, chrome and white except those LED's? Naaw... :D
  7. marcoboy
    5 Mar 2005
    yes, you are right. And i've thought about it many times, but.... there's SO MANY tiny components (and many layers of wires) on the mobo surface there, that I would probably end up broking my mobo :(
    Those capasitors that I soldered were a bit different: there were room around those to work.
  8. kickarse
    kickarse What's a Dremel?
    6 Oct 2004
    Fire + Plexi = Melting Inferno!
    Can't wait!
  9. marcoboy
    5 Mar 2005
    Melting wires...
    Here are the wires for LED lighted case feets:
    As you can see, placing ridiculously thin wires between tightfitted PSU and plexi results in..... SHORT SIRCUIT !!! HAH ;)
    And that current (3.3v) was taken straight from "wakeup" line of the PSU.
    My home smelled of melted plastic for hours and those little wires burned my fingertips quite nicely ;)
    But..... let the modding continue :dremel:
  10. perplekks45
    9 May 2004
    Noob-ish failure. :worried: :D
    Keep going man, this is more than nice.
  11. marcoboy
    5 Mar 2005
    Complitely off topic
    Hi,
    This is a bit off topic, but I decided to post it in this thread..
    My upcoming HTPC-case. (I allready have it up and running as my DVB TV, but without case!)
  12. perplekks45
    9 May 2004
    Uhm... those 'balls' on the HTPC, what are they good for? :D
    And what materials will you use? Plexi? ;)
  13. marcoboy
    5 Mar 2005
    Working and phase one completed !!!!!
    Everything works just fine :)
    I've marked the place where I must place my special key...
    ...that I use to power ON/OFF my computer.
    Phase two (in the distant future, far far away) will be including Fanbus, Temp-display behind sidewindow, Lan-led on frontpanel.
  14. Pete_Venkman
    Pete_Venkman What's a Dremel?
    20 Jul 2005
    SWEET paintwork! That combo turned out nice. I also love the motherboard cover idea, I've seen it a few other places but not with perforated metal yet...that looks tight. Have you thought about covering the video card as well? Those monster heatsinks look a little sore-thumbish.
  15. compwiz
    compwiz What's a Dremel?
    28 Jul 2005
    all i have to say is wow. awesome case. i have to say you have some balls messing with the motherboard. but all turned out well. what are you using as the on/off switch?
  16. marcoboy
    5 Mar 2005
    I used this switch: http://forums.bit-tech.net/showpost.php?p=915052&postcount=24
    Bought that from "Bebek" (small Finnish electronics shop). Cost about 30€.
    Switch is made by KEMO (German DIY -kit manufacturer)
  17. Rain
    Rain What's a Dremel?
    16 Jun 2002
    Very nice work :rock:
    Motherboard stealth is very original, never seen that before :clap: :thumb:
