Project: Miranda (changed!!)
Discussion in 'Project Logs' started by Razor_cut, 15 Feb 2005.
  1. ReFredzRate
    ReFredzRate Relix Headshot!!
    2 Sep 2002
    That looks to be one heavy mother when it's done! :naughty:
    I really love those types of Lian Li cases. They're huge.
    Will you mod the evaporator casing as well to match the PC2000B?
  2. Razor_cut
    Razor_cut New Member
    12 Mar 2004
    Dont you think there will be quite a bit of heat to take care of in that case with an 70C compressor? That case looks to be more for the quiet user..
    Well I havent fit the compressor yet.. Couse Id like to try the compressor out before throwing the garanties away. But the memmory Im waiting for sholud leave a german stor yesterday and reach me in the middle of next weekend or so. Then after the tryout there will be the havey modding :dremel:
    And yes, there will be simple 12cm blow holes to cool the compressor down, and Im going to seal the roof of betweene the motherboard and the comp, so not so much heat will rise..
    How do ya mean? :hehe: The compressor will be taken out of it currently case and mount on a steal plate, witch will be stiffed inside the 2000B..
  3. M1ndZtorm
    M1ndZtorm New Member
    8 Feb 2005
    Well, as I said. The original idea was to use the 1100 case, however that was dropped 'cause the VapoChill is to big (or the case is to small :D ) Since then I've ordered the Lian-Li PCV2100B, which is like yours except mine will sport sound insulation as well.
    I choose that case because I want the 'puter to be as silent as possible (well, perhaps the VapoChill shouldn't be in there 'cause the noise, but hey! I'd like the rig to fly as well :hehe: )
    Regards,
    Karl
  4. Razor_cut
    12 Mar 2004
    A minor update.
    Cant realy say how much I love that FMJ, its heavy nicely bent corners and so on :thumb: . The jacket will get some chrometion later on :dremel:
    As you well can see on this picture, the fan grill is pritty bigger then the fan. But it will be taken care of, so it fits the BIX later on..
    Rock on!
  5. blknoel
    blknoel New Member
    14 Jun 2004
    Not to put your enthusiasm off or sumthing, but I never feel the need to watercool HDDs :D
    I put my HDD in the 5.25" bays, stick a silent 120mm fan in front of them, and they never go above 25*C (I've seen most 22-24)
    Those HDD waterblocks are not doing u a favour, they are restricting flow only, even on your uber powerful Eheim :)
    Just my 2 cents :D
  6. Razor_cut
    12 Mar 2004
    Well tru with the 120cm fan, but with the waterblocks I probably could put som soundresistant material or so over them. With air cooling the HDDs would burn :thumb:
    But its a *for the eye* thing also. The blocks will stay as long they prove them selfs worthy.
    So you think the 1048 whont take the resistance? Im quite new with the 1048 since Iv used a 1250 before. But since the radiator only will be a BIX/BIP and MAZE4 on the GPU and the HDD blocks, Im would be supprized if there would be bigger problem then some light resistance..
  7. blknoel
    blknoel New Member
    14 Jun 2004
    In that case its OK :D
    But a 120mm fan spinning at low rev is not noisy either.
    However that option would not fit your situation, as u are using some Noise reduction material for your HDDs.
    Everything is neat and clean so far, so keep it up :)
  8. Firehed
    15 Feb 2004
    It's a really good idea if there's low airflow like in most watercooled setups. Not critical but still better safe than sorry, especially with your data.
    A couple questions about those HDD blocks... where'd you get them, how much and what type of thread is on the fittings? And if you mount them as far towards the back of the case as you can, how much clearance is there to the front of the drive rack (trying to see if my LCD might fit in front :D)
  9. M1ndZtorm
    8 Feb 2005
    :search:
    /Quote/ Well its a enginer i Sweden who makes them.. But if you are nice maby he would make some for ya... Try this webbpage = http://hj07.dyndns.org/ its in swedish but have a try /End Quote/
    :rolleyes:
    Kind regards,
    Karl
  10. ReFredzRate
    2 Sep 2002
    I've seen the FMJ a few times around some different forums. Looks to be one helluva choice you made on using it! :thumb:
  11. M1ndZtorm
    8 Feb 2005
    I want some updates and new pic's :rock: , it's been silent in here for a while now :worried:
    I'm very interested in learning more about your plans for the VapoChill :brrr:
    Kind regards,
    Karl
  12. Razor_cut
    12 Mar 2004
    You will get them :D
    Thanks for the thought :thumb:
    All the shots are in 2048x1536 so thers only links for now..
    Quite manny of them are quite the same, but maby some joy on the late eve :hip:
    Random shots on mobo, memmory.
    http://img7.exs.cx/img7/8820/core0015gz.jpg
    http://img78.exs.cx/img78/1051/core0020ar.jpg
    http://img78.exs.cx/img78/7898/core0036pa.jpg
    http://img78.exs.cx/img78/4683/core0042rw.jpg
    Condesation compound on the socket.
    http://img207.exs.cx/img207/9641/core0109zz.jpg
    http://img78.exs.cx/img78/5069/core0083ht.jpg
    http://img207.exs.cx/img207/4420/core0114cu.jpg
    http://img207.exs.cx/img207/6029/core0123ea.jpg
    http://img193.exs.cx/img193/8238/core0164fb.jpg
    Nice reflection :lol:
    http://img193.exs.cx/img193/4682/core0184xe.jpg
    http://img175.exs.cx/img175/4776/core0194tu.jpg
    LS mounting condensation ready. (skinn really dosnt look good on near view) :worried:
    http://img175.exs.cx/img175/3561/core0255oy.jpg
    http://img87.exs.cx/img87/9483/core0277ur.jpg
    http://img87.exs.cx/img87/1171/core0266ia.jpg
    After some hours :idea: But no idea to hurrie up, quit nice thoe..
    http://img105.exs.cx/img105/7820/core0287fd.jpg
    http://img105.exs.cx/img105/9130/core0291cr.jpg
    http://img105.exs.cx/img105/2743/core0326zi.jpg
    http://img105.exs.cx/img105/4876/core0307hr.jpg
    http://img171.exs.cx/img171/5482/core0334ib.jpg
    Finnished for tonight... But it is quite manny cables, so I can garanti some serious modding soon. :thumb:
    http://img171.exs.cx/img171/4241/core0345nb.jpg
    http://img153.exs.cx/img153/5851/core0354tr.jpg
    Time to take a nap, more action for tomorrow!
  13. eclectik
    eclectik New Member
    2 Dec 2004
    Is that is OCZ VX and DFI NF4 Ultra D?
    ECK
  14. Tim S
    Tim S OG
    8 Nov 2001
    for dual channel you need to be using slots 2 and 4 (the orange ones) on the DFI nF4 SLI-DR/nF4 SLI-D/nF4 Ultra-D boards.
  15. uwannabigmak
    uwannabigmak New Member
    30 Dec 2004
    what you should do is watercool the vapochill... that would be cool... pretty hard, though.
  16. Razor_cut
    12 Mar 2004
    Are u certain? because DC should be with diffrent shannels. Yellow and orange for DC. Or is it like u say?
    Becous on MSI K8N NEO2 theres DC with the different collors..
    Your right, ofcourse :duh:
    For DC on nF4 DFI its channel 2-4/1-3
  17. eclectik
    eclectik New Member
    2 Dec 2004
    You're right, according to the manual and a few pics I've seen.
    ECK
  18. Is it a question..
    Is it a question.. New Member
    27 Feb 2005
    just being curious... i can take a guess on what the condensation compound is for and what it prevents i just dont understand how the cpu and compund are fitted? very jelous of the case.. very nice :thumb:
    sos bout the late pick up aswell but are those IDE HDDrives uve got strapped between ur watercooling blocks? surely you want something a bit spicier and faster.... or am i just slow this morning? :jawdrop: ... sleepy. sos long night.
  19. Mosha
    Mosha New Member
    31 Jul 2004
    Dude, is it just me or are the pictures really low quality or badly taken?
  20. Isuo
    Isuo New Member
    13 Oct 2004
    Nope, it's not just you. The image quality seems to be pretty low and blurry.
