Project: Miranda (changed!!)
Discussion in 'Project Logs' started by Razor_cut, 15 Feb 2005.
  1. Starbuck3733T
    Starbuck3733T Look out sugar, here it comes
    16 Sep 2002
    Do those handles only come in chrome? what are they made out of? AL? Steel?
    Would you be willing to ship some of those swedish HDD blocks to the USA?
    Very nice work.
  2. Razor_cut
    Razor_cut What's a Dremel?
    12 Mar 2004
    HDD blocks you will be able to find here and hopefully for sale :thumb:
    Mail
    The Handels are made of steel yes and what I saw they were only in chrome..
  3. Nexxo
    23 Oct 2001
    I did. (you should know by now that every mod to Metaversa has an actual functional purpose ;) ).
    This looks pretty impressive already. I'll be keeping an eye on this one.
  4. Razor_cut
    12 Mar 2004
    Im going to chose pump between these two 1048/1250 (Ehime) With my system;
    Pump - rediator - gpu block - 2x Reservoir - PSI meter - HDD block, and around.
    Do you think it will be enought with the 1048? or will it pump to slow to be effective?
    Cheers
  5. leviathan18
    leviathan18 What's a Dremel?
    17 Mar 2005
    razor cut how much does the case weights empty???? i just want to know to make my desition to buy it or not i go to a lot of lan and i want a light weight case
  6. Razor_cut
    12 Mar 2004
    Empty, well dosnt take much mussle to lift. Since everything is in alu its really light weighted.
    Lian li always make me supprised when lifting the case for the first time :thumb:
  7. Razor_cut
    12 Mar 2004
    Decided to put the pump in a vertical position and made some scratches on the paper, this is what came out:
    The two bricks will be made out of alu, with some nice screws to hold the FMJ in place.
  8. mnpctech
    mnpctech bit-tech sponsor
    21 Apr 2003
    Razor, have you seen about my new case handle design? They're machined from billet aluminum. Should be avail by mid July.
  9. Selbstmord
    Selbstmord What's a Dremel?
    28 Jun 2005
    It's purely refreshing to finally see some Swedes take a crack at using compressor cooling...
    (det ser jävligt bra ut hittills, fortsätt!)
    edit: on a sidenote; damn those are some very nice handles...
  10. Razor_cut
    12 Mar 2004
    Thats a nice handle, but compared with your mnpctech pro-line (blow hole), I think its more breathtaking. :thumb: But they would fit nice togheter..
    Will you have more colors available?
    In second thought that handle would justify the weight of this case more then the smal ones that are in place at the moment.
  11. Razor_cut
    12 Mar 2004
    All the metal has been orderd now, hopfully the shipment will arive this week. But Im not sure how long it usualy take for them to cut the peaces. Its mainly aluminium, and some steel for the cromefactory to lay their hands on ;)
  12. mclean007
    mclean007 Officious Bystander
    22 May 2003
    Nice Mod! Sorry to go o/t but have you seen this on the site you linked to - that, my friends, is a 1.4 GHz Celery cooled with dry ice at 3.75 GHz, which is a whopping 168% above stock. That's the kind of O/C I like to see!
  13. Razor_cut
    12 Mar 2004
    Yeah its a oc that takes some air out of ya :thumb:
    you never gona know what LN2 will do with your OC'ing.
  14. Razor_cut
    12 Mar 2004
    Up working !!
    Well its back on the road, and for thous who know that this modd needs money, knows that Iv been working. So financially its back on track. But my feelings have changed, so Iv dumped the Vapo Lightspeed compressor. Im now going for watercooling, hopefully with a clear and nice finich.
    There will be two water lines, two Ehime 1048 with FMJs etc. Swiftech Storm and other intressting details.
    Iv orderd one more pair HDD block so we can handel 4-6 HDDs.
    Some pictures to show how they will be mounted, the alu pice is from the ripped PCV2000B. And will be stuffed in between the Powersuply and the pumps that will stand beside eachother.
    The other blocks should arive anny day now, then we have 8kg copper block, and nice 12kg with Hdd mounted :thumb:
    Have some things coming next week that hopefully will help to start the actuall mod.
  15. frodo
    frodo What's a Dremel?
    1 Nov 2003
    personally, i think you should fabricate a hdd waterblock holder, as then you would eb able to see more of those sexy blocks!
    i want some of those hdd blocks now ;)
  16. Razor_cut
    12 Mar 2004
    Well I need some Alu to make them more viewable, but its hard to come around right now. Well to the point, I orderd like I said some more HDD blocks from hj07 and here you can see before and after polishing shots.
    Tools; Autosol, 800-1200-2000 grid, socks and some hours..
  17. noCode
    noCode What's a Dremel?
    16 Oct 2003
    Mmmmm, Dumle!
    But the blocks are even more mouth watering!
  18. VERY nice modding here mate! Love the ultra reflective blocks! The case handles look really sharp, lol
  19. Jipa
    5 Feb 2004
    Hmm.. Those "handles" make me just wonder, can they even take weight of that case? I mean screws don't have too much metal to stick on...
    And other thing about handles is can you really lift your computer fron those? Pity your fingers :D
    And oh, got to say this: Dumle rocks ;)
  20. Razor_cut
    12 Mar 2004
    Well well, the handels story again? If you whant to read about it look at the previous page or so. There will be either alu or arcrylic under the chassi thats naild to the handels. Then the weight will easly been taken care of.
    And for the last time, its more estetic than functional!
    :thumb:
