Case Mod - In Progress Project: c-black (Migui 2)
Discussion in 'Project Logs' started by MIGUI, 15 Apr 2009.
  1. The boy 4rm oz
    10 Apr 2008
    Rad looks great mounted, I love the fans.
  2. ModaRobby
    ModaRobby What's a Dremel?
    5 Aug 2009
    fans look much better than normal square case fans. What fans are they exactly? This is gonna be a great case mate.
  3. Redsnake77
    Redsnake77 Useless Idiot
    7 Jun 2009
    Great mod! Aren't those fans going to suck cool air through the rad from outside, with the air heating up through the rad and blow hot air into the case though?
  4. eegg
    eegg What's a Dremel?
    29 Aug 2006
    I have used that compressor before and they give off lots of heat so maybe you shoud isolate cool it off somehow so it doesn't affect the computer temp
  5. MIGUI
    MIGUI What's a Dremel?
    27 Feb 2009
    Hi guys.
    I'm back with more updates.
    I'm doing a cover that anger in the right side alongside regulators and valves pneumatic circuit. Behind this piece is mounted one of the two cylinders that raise the case.
    Use two of these cylinders for the 5 cm to raise the case.
    Soon more updates.:thumb:
  6. disturbed13
    disturbed13 Minimodder
    28 Nov 2008
    okay
    i just got out of the shower
    and just watched your vid
    now i need to change my shorts
    thats just to damn sexy
    great job btw
    thats an amazing project to say the least
  7. MIGUI
    27 Feb 2009
    Thanks dude. :thumb:
  8. The boy 4rm oz
    10 Apr 2008
    WOW, I just noticed the amount of cables you have to work with lol, good luck :thumb:.
  9. MIGUI
    27 Feb 2009
    Yes The boy 4rm oz, are much cables.
    More updates.
    I've put a bolt to the dump valve as being behind the cover along with the cylinder, so only a small hole with the cover will be enough to turn it.
    I have also mounted the left side cylinder.
    perplekks45 likes this.
  10. perplekks45
    perplekks45 LIKE AN ANIMAL!
    9 May 2004
    The attention to detail is unbelievable! If you keep up that level we'll have a contestant for GotY here. :thumb:
  11. Bad_cancer
    Bad_cancer Mauritius? 2nd speck east of africa
    7 Apr 2009
    GotY=God of the year?
    Does this mean that bit-tech is like Egypt? in that case i vote for:
    -g69t as the god of metalwork.
    -oldnewby as the god of awesome detail.
    -migui as the god of things that go phssst.
    -john as the god of all knowingness.
    -mankz as the trolling god.
    -bill as the god of epicness.
    -brad as the paint god.
    -e.e.l as the god of nibblingness.
    and bindi as the god of the ban hammer (kinda like a modern thor) lol
  12. stonedsurd
    11 Mar 2009
    Talladega as the god of all memes.
  13. AnG3L
    AnG3L Ultimate Modder
    19 Mar 2009
    My friend! Long time no see! How are you? I see your job and its fantastic as always! I really love the detail and the neat beauty of this project!!! Go on buddy!!!! :)
  14. Richh999
    Richh999 Small Time Modder
    9 Oct 2008
    I'm loving the case desgin and the amount of detail gone into with the phenumatics...
    Cheapskate - God of all things needing blame..
  15. MIGUI
    27 Feb 2009
    Thanks for the comments guys.:thumb:
    Update.
    I already have the cover painted and mounted to the cylinder and dump valve.
    The hole with the rubber bushing is to open / close the valve (this serves to empty the pneumatic circuit) with an allen wrench through the screw, which I put to the valve, so it is more concealed.
    Also I put the cylinder on the right side.
  16. perplekks45
    9 May 2004
    This is beyond awesome! :rock:
    rep++
  17. disturbed13
    28 Nov 2008
    lookin great
    keep it up!!!!
  18. MIGUI
    27 Feb 2009
    Hey guys.
    I already have the feets who uses. A friend of manufactured, on his front feets are fixed cylinder rods that raise the cash.
    The feets are made of aluminum which then sends you to anodized or painted black.
    This is the bottom of the feets, the recess that is here is to put some rubber or something similar as the other feets of the cases.
    The two front feets take this bar to prevent movement (spin) and the rod of the cylinders are not fixed.
    This is the idea.
    Regards.
  19. perplekks45
    9 May 2004
    They'll be anodized black? Niiice! :thumb:
  20. ModaRobby
    5 Aug 2009
    cant wait to see this done. lookin amazing already.
