Project: Chrome Dragon? *UPDATE* DONE!! NEW PIX!
Discussion in 'Project Logs' started by Bboy_Jon, 1 Feb 2005.
  1. Bboy_Jon
    Bboy_Jon Minimodder
    28 May 2004
    Ok well i dont have any real theme or anything, im just going with what i got. I bought my new case, a chieftec full tower which WAS on sale for 30 bucks, and i think there sold out, heres some pics of my case
    So far what i have planned out is
    PSU template, so it sits horizontally
    Cut out grills for fans
    120mm blow holes
    window (maybe a top one too)
    LCD
    O btw, keep in mind, i may not have too many updates very often (i think) because ive got alot of homework and stuff :waah:
    Anyways, my PSU came in, fortron blue storm ax500-a YAY :D
    Box
    Whats in the box?
    heh the manual
    Back
    fan
    Now my psu holder. Originally i was going to use 2 power supplies, and i easily can but its too much of a hassle and i dont need it, i may just put a 120mm fan where the 2nd psu would go
    So here goes, template all cut out, look at the back of my case for how it looked originally, i also was polishing the edges with the wire brush attachment for my dremel and i tried it on the piece and it started to polish it so i was like crap, but i just had to finish the whole thing then (i dunno why i did it) but it turned out OK
    In case
    Psu in the case, woops backwards, the fan is pointing up :wallbash: :duh:
    side view
    i can put it on top with the fan pointing down
    but i can only use 3 screws
    anyways good news about that, the fan blows air, it doesnt suck air and out of the case, but sucks in air into the case and blows it, so now i have it point up so the hot air will just go right out, if i put a blow hole there
    and umm heres my dog, i wanted to take a pic of him and my other dog in the case, to show how HUGE it is but hehe whatever
    o and i cut the 2 back grills, and 1 of the 3 grills in the front (pic was taken before the front grill was cut)
    I wanted to cut out the rest today but too much hw :waah:
    Anyways, more updates whenever i get the chance (hopefully tomorow i can cut the rest of the grills and maybe a blow hole, i wish i had a 120mm fan at hand :( )
    I cant decide on a window design, can you all look at my topic in the modding section?
    Window design topic
    Like i said above, i probly wont have too many updates to often
  2. antiHero
    antiHero ReliXmas time!
    19 Jan 2005
    looks promising keep it up :thumb:
  3. Silenced`
    Silenced` What's a Dremel?
    28 Aug 2004
    keep on the modding, and keep us updated.
    grtz,
    Thomaz
    ps: we have the same dog at home :blush:
  4. Bboy_Jon
    Bboy_Jon Minimodder
    28 May 2004
    KK I cut the last 2 fan grills on wedsday i think
    that hole, i made today its for my front usb/headphone ports
    I cut my usb and firewire pci attachment that came with my mobo and added my own headphone port i wired up
    Here it is mounted
    and here is the front view
    Now i feel really stupid, because it took me from 5 PM to 10 PM to do that. I feel stupid because i screwed up when drill the mounting hole so the thing wanst flush with the case, if i had just drilled a second hole to remount it then i could have saved my self 5 hours and i ended up doing it anyways, so it looks kinda crappy
    Anyways.....I started to cut the "mobo hole" today so i can route/hide my wires easier
    Last night i ordered 2 120mm Deltas, with 130cfm :) and 3 120mm fan grills for 12.63 or something
    Also today i went to home depot and picked up some stuff
    *a 24x24 (or bigger, i forgot the EXACT size) sheet of acrylic
    *an 11x24 i think, sheet of acrylic
    *wire brush dremel attachment
    *5 reenforced dremel cut off discs
    *1/8, 7/64 and a 3/32 titanium metal cutting drill bits (YAYA) btw which size drill bit is used for fan screws and case screws? plz tell me i got the right size
    *some washers
    *2 10 packs of bolts and nuts, couldnt find pop rivets or other screws but thisll work for my window
    *2 head duty handles that fold, i was gonna get the garage door handles, but there so ugly and i want foldable handles
    *bi-metal jig saw blades
    heres my HD reciept
    heh, there goes the rest of my x-mas money and like 2 months of saving my allowance
    and i also went to walmart and got
    *Masking tape
    *velcro with adhesive backs
    *2 barbeque grill things, its my mesh!!
    thats all for now, tomorow i HOPE to finish cutting the mobo hole, and cut the thing that sits above my mobo tray and beneath the psu
  5. Zephyr
    Zephyr Go V-Boy, Go!
    1 Oct 2004
    Looking good -- what do you plan on using the mesh for?
    Oh, and nice ghetto-grab with the grill-holders :hehe:.
  6. Anthony
    Anthony What's a Dremel?
    6 Jan 2005
    Oh it´s barbaque-grill thigie, what people use on their mods!! I have looked at it on some stores, but now i will find it!!
    Btw, good luck mate! :thumb:
  7. joefishy
    joefishy What's a Dremel?
    10 Jul 2004
    Lorem ipsum dolor sit amet, consectetur adipiscing elit, sed do eiusmod tempor incididunt ut labore et dolore magna aliqua. Ut enim ad minim veniam, quis nostrud exercitation ullamco laboris nisi ut aliquip ex ea commodo consequat. Duis aute irure dolor in reprehenderit in voluptate velit esse cillum dolore eu fugiat nulla pariatur. Excepteur sint occaecat cupidatat non proident, sunt in culpa qui officia deserunt mollit anim id est laborum
  8. Bboy_Jon
    Bboy_Jon Minimodder
    28 May 2004
    see this case
    that same mesh that he used, is the barbeque grill things :D
  9. Bboy_Jon
    Bboy_Jon Minimodder
    28 May 2004
    *Update*
    KK, well for my handles i needed some bolts and nts so i went to walmart and picked up a bunch of stuff, all cheaper than at homedepot, so no more HD for me Walmart ALL THE WAY!!
    anyways i got my mobo hole cut
    what pisses me off is that i left my room, and when i came back my dad was there cutting the hole. He finished off one of the sides i was on and started on the next side. WTF its my f**kin mod, why doesnt he go and get his own frickin case, dammit i hate when he starts cutting my stuff, after a while its no longer gonna be MY mod, but me and my dads mod WTF, i was so mad i through a table hahah (not at him :D )
    and i finally cut the thing that seperates the mobo tray and the psu! its taken me two weeks to finally go and cut that thing dang
    Ok well now all the basic ESSENTIAL mods are done (mobo hole for routing my wires, mobo seperator, fan grills cut, front usb/headphones) its time to start doing my real mods
    *Blow holes
    *handle mounting
    *window
    *mounting LCD
    *meshing the front bezel
    K thats probly the last update until the weekend (hopefully not) but ya school is a biatch :(
  10. Bboy_Jon
    Bboy_Jon Minimodder
    28 May 2004
    *UPDATE*
    Kk i got my new 120mm fans and grills
    the fans are 120mm Deltas 130cfm
    o btw I NEED A WINDOW!!!!!
  11. duggyb
    duggyb What's a Dremel?
    8 Feb 2005
    looking forward to an update :rock:
    Duggy :dremel:
  12. CaseyBlackburn
    CaseyBlackburn Network Techie
    27 Jul 2004
    already a true bit-techer using orthings as mesh and its looking very great
  13. Bboy_Jon
    Bboy_Jon Minimodder
    28 May 2004
    *UPDATE*
    Ok well i moved my psu holder thing
    Upclose, i had to drill a hole to move it down, so it dont block my psu fan
    Heres a draw up of the handle and blow hole positions
    Handles installed
    Woot handles work
    Half of a blow hole
    WOOT first blow hole is cut!
    Both blow holes cut
    Fans and grills and handles mounted
    Inside the case
    woot upclose!
    pretty dam good job for my first blow holes!
    OO, heres some stuff plugged into my front ports
    Ok now i decided to put my psx controller to usb adapter built into the case, can i change the external port into a internal port?
    Heres the adapter and my cut out drawing
    heres how i mounted it, had to drill some holes in the adapter
    and on the inside
    Heres the hole
    Pretty bezel
    WOOT what u know about that
    Ok anybody have an idea how i can cover this?
    I cut the hole before i mounted it so i started too low, im thinking of putting a rubber cover over it (like those on cell phones that cover the headset port and the charger port) or a acrylic door but i dunno how to make it!!!!!!!! ahhhhh
    thats all for today i think
  14. CaseyBlackburn
    27 Jul 2004
    are you going to be moving this pc around alot because it looks like it would weigh a ton
  15. Bboy_Jon
    Bboy_Jon Minimodder
    28 May 2004
    not really, just to the occasional lan party (about every 2 months or so)
  16. GigantoR
    GigantoR What's a Dremel?
    21 Jul 2004
    Lookin good, those steel chassis are a b**** to work on. Nice clean cuts and design so far. So glad you got rid of the seperator. That thing ruins the look of those cases interior to me.
  17. Bboy_Jon
    Bboy_Jon Minimodder
    28 May 2004
    hell ya the seperator is craazy!
  18. GigantoR
    21 Jul 2004
    Yeah I gotta get home to my jig saw. I'm at college right now and just have my dremel clone. It takes about a billion cutting discs goin through the steel of my chieftec.
  19. CaseyBlackburn
    27 Jul 2004
    one question does the sound cable obstruct the 2nd usb port because it looks like it would
  20. Bboy_Jon
    Bboy_Jon Minimodder
    28 May 2004
    OOO i never thought about that, but i just tried and it works fine, theres just enough space for the headphone jack to rotate around freely
    O ok, on the front usb ports, i was looking at the header and it uses 8 wires, 2 white, 2 red, 2 green and 2 blacks, that means theres one set for each port?
    so i just copy that, with the psx adapter wires right? and id only use one row of headers on the mobo?
