Project: Chrome Dragon? *UPDATE* DONE!! NEW PIX!
Discussion in 'Project Logs' started by Bboy_Jon, 1 Feb 2005.
  1. scifi3018
    scifi3018 Minimodder
    6 Feb 2005
    i wouldnt have the windows on the drive bays, as they are UGLY, unless you plan on doing some thing to them...
    [RANT]
    also, next itme you need somehting for your case, instead of aksing repeatedly where in walmart it can be located, GO TO WALMART AND ASK, as every walmart i have been to has different arraingments, ans differents organization.
    [/RANT]
  2. CaseyBlackburn
    CaseyBlackburn Network Techie
    27 Jul 2004
    well he was asking for what section i bet and at all walmarts everything is in the same section
  3. Bboy_Jon
    Bboy_Jon Minimodder
    28 May 2004
    ya sure walmart will have different layouts of the sections (paint in the southern part of the building, automotive in the north etc) but usually bondo is where it would be in all places (auto i guess) paint will always be in paint, drills will always be in the tools
    that shouldnt change :D
  4. Bboy_Jon
    Bboy_Jon Minimodder
    28 May 2004
    Ok well i went to walmart and spent 98 dollars! i bought sand paper (shoulda gotten a variety pack), spray paint (6 cans), some dremel bits (carbide cutter and diamond set), sanding block, bondo, screws and some other stuff i cant remeber, id get a pick but im too lazy
    Soooo anyways i started to cut my dragon window
    i only cut that much so far, my discs arent small enough yet
    thats all for now
  5. JoyRider
    JoyRider What's a Dremel?
    7 Jun 2004
    Don't forget what I've posted in your other thread. I've only used dremel discs for my first and second side panel so I can't give you advice on how to use the carbide cutter and such.
    Because the discs were too large, I used them for the large sections untill they got smaller. Then I saved them up and finished the large parts. After that I did the smaller parts - edges - corners etc. etc. with the smaller discs.
    @adamjones01101
    I saw his design; the edges and corners aren't that tough. Remember, I've only done two side panels so far with the first one a dragon concept and 2nd a spiderweb concept. If you have the patience to figure out how to do it effeciently, then nothing is impossible in casemodding.
  6. Bboy_Jon
    Bboy_Jon Minimodder
    28 May 2004
    do you think i should solder on mobo headers to the psx adapter or just pull it through a pci slot and plug it in externally?
  7. Bandit_zoraK
    Bandit_zoraK What's a Dremel?
    29 Nov 2004
    I would say that when using the carbide cutter, go very slow and have a very firm grip as it tends to kick back if you are going too fast. Good luck!
  8. Bboy_Jon
    Bboy_Jon Minimodder
    28 May 2004
    go slow as in slow speed or go slow as move ure hand and dremel slow?
  9. Bboy_Jon
    Bboy_Jon Minimodder
    28 May 2004
    *UPDATE*
    kk well i cut some more outta the window
    im hoping to finish on saturday (i gotta wake up early if i wanna finish)
    What can i do on the other side? a temple? (need a pic) or maybe the amd logo? i dunno
    i also bondoed some crap on my bezel
    thats all
  10. Bandit_zoraK
    29 Nov 2004
    The latter.
  11. Bboy_Jon
    Bboy_Jon Minimodder
    28 May 2004
    ook so i keep it at max speed, and just use 2 hands?
    ya i was using the high speed cutter (its not suppose to be used on hard metals i think hehe) and ya i was using it on my blow holes and it kicked back like crazy and it looked like there was a bite outta my case from it
  12. Bboy_Jon
    Bboy_Jon Minimodder
    28 May 2004
    *UPDATE*
    KK i cut the body of the dragon
    I also did the tail and started some of the head, but no pics of it, i also sanded down my bondoed bezel but when i took a dremel to it, it ripped the bondo off. Does it matter if the bezel is really roughed up? cuz ya it got sanded too, but thats good so the paint can stick to it right?
    anyways thats all for now, hopefully i can finish at least the dragon tomorow
  13. Bandit_zoraK
    29 Nov 2004
    I would say that you should sand the thing down untill it is smooth but it has some sort of texture to it so the paint can adhere. Well keep it up, good luck wit dem details on tha drizagon
  14. Bboy_Jon
    Bboy_Jon Minimodder
    28 May 2004
    ok well for painting, do i need to take the top off? i dunno if i can trust the machine screws id replace the rivets with since i got a heavy ass case with really little room for the handles to hold onto (due to the blow holes) so after i paint the top, can i tape the sides with painters tape? so i can do the inside and not get any paint on the top?
    would painters tape peel off the new paint on the top panel?
  15. Bboy_Jon
    Bboy_Jon Minimodder
    28 May 2004
    *UPDATE*
    kk this was from two days ago
    cut the tail and most of the head
    im gonna finish the head later today and maybe finish the arms (doubt it)
    and i think ill call it chrome dragon? sounds like its been done though
  16. Anthony
    Anthony What's a Dremel?
    6 Jan 2005
    My gosh... Very nice
  17. Bboy_Jon
    Bboy_Jon Minimodder
    28 May 2004
    i cut the head out (but f**ked up a bit, the nose was too big) so i bondoed it and i cut 1 1/2 arms
    pics tomorow
  18. Bboy_Jon
    Bboy_Jon Minimodder
    28 May 2004
    *UPDATE*
    Yup finished the head (sorta) and started an arm and got one done
    but it looked funky cuz the whiskers? on the dragons chin were too dam big so i bondoed and im gonna try it again
  19. duffman30
    duffman30 What's a Dremel?
    24 Oct 2004
    Those dremel cutting disc's how long do they last?
  20. Bandit_zoraK
    29 Nov 2004
    Still looks pretty good! Keep it up.
