Project: Chrome Dragon? *UPDATE* DONE!! NEW PIX!
Discussion in 'Project Logs' started by Bboy_Jon, 1 Feb 2005.
  1. CaseyBlackburn
    CaseyBlackburn Network Techie
    27 Jul 2004
    ok good because i was like i am hopeing he doesnt need that second one
  2. CaseyBlackburn
    27 Jul 2004
    you asked earlier how to plug to psx adapter internally just soder the wires to the usb header
  3. Bboy_Jon
    Bboy_Jon Minimodder
    28 May 2004
    ok so i dont need anything fancy? i just gotta match the right colored wires with everything?
    any ideas about this
    o and i just tried the headphone thing again using the headphones i use at lan parties (its a 3.5mm jack so i use a converter) and with the converter in it just barely blocks the 2nd usb port, so ya i cant use it, but i NEVER used 2 front ports at the same time, and i only use the headphones at LANS and i never plug anything into the front usb anyways
  4. CaseyBlackburn
    27 Jul 2004
    for the holes try bondo
    and for the usb just match the wires to the correct header
  5. Bboy_Jon
    Bboy_Jon Minimodder
    28 May 2004
    Ya i need to get some bondo though, does walmart have it? how much is it at home depot and stuff?
  6. CaseyBlackburn
    27 Jul 2004
    walmart might im not sure but HD probaly will and im not sure on price
  7. CySlyde
    CySlyde What's a Dremel?
    30 Dec 2004
    walmart carries bondo, and if you go to ratshack they used to carry a adapter to go from 3/8th to 1/4 with about 2" of wire so you can get that and still use your second usb
  8. Bboy_Jon
    Bboy_Jon Minimodder
    28 May 2004
    cool ill check walmart next time i go
    i may do a lil sliding door thing,made out of a cd jewel case
    dang i still need a window design
  9. Bboy_Jon
    Bboy_Jon Minimodder
    28 May 2004
    any ideas how i can cover up some of the ps1 controller port hole?
  10. Cowinacape
    Cowinacape What's a Dremel?
    26 May 2003
    Looking good so far, will keep an eye on this to see how things progress for you. :hip:
    Go to ask though, just out of curiousity, did you happen to get this case from Tiger Direct? I just picked up two of these same cases (in black mind you) from Tiger, and managed to get them for $40.00CDN apiece.
  11. Bboy_Jon
    Bboy_Jon Minimodder
    28 May 2004
    ya i got it when it was on sale (and when they had the case) for 30 bucks
  12. scifi3018
    scifi3018 Minimodder
    6 Feb 2005
    for the hole, if bond-o isnt good for you, then try filing it!!!
    Also if you file around the usb ports,it will look much cleaner
    Other than that, what colors are you going for?
    Another thought, get a peice of heatshrink tubing to cover the end of the green wire sleeving on the usb extension ports, it will look cleaner, unless you have something else in mind
    Good job
  13. Bboy_Jon
    Bboy_Jon Minimodder
    28 May 2004
    filing will make the hole bigger
  14. Bboy_Jon
    Bboy_Jon Minimodder
    28 May 2004
    *UPDATE*
    Ok well i made my ghetto psx adapter cover thing, held on by a cable tie, and made of a mouse pad and some carpet LOL
    I painted it silver, but i havent got any pics of it yet
    anyways, made a hole for the heatsink, so ill put a fan on the other side panel
    And i cut my front bezel up WOOT! :rock:
    i went all over it was fun, but it took me about 4 hours to cut it all out
    FINALLY!
    If your wondering why i left those things, youll see
    hmmmmmmmmmm why did i cut out the bezel crap again? o ya!!
    thats my pimping walmart grill mesh crap WOOT! and if you havent noticed, i left those things to mount the lcd.
    Tomorow im gonna paint the grill blue woohoO! i MAY also do my window, if i can think of something to do that is
    thatz all for now
  15. Dean_j2001
    Dean_j2001 What's a Dremel?
    1 Apr 2003
    looks real funkeh with lcd installed good stuff :)
  16. CaseyBlackburn
    27 Jul 2004
    that cover is really..."ghetto"
  17. Bboy_Jon
    Bboy_Jon Minimodder
    28 May 2004
    ya it was the only/easiest thing i could think of :D
  18. Bboy_Jon
    Bboy_Jon Minimodder
    28 May 2004
    *Small Update*
    Painted the mesh
    and made a new cover, using velcro
    thats all
  19. striker289
    striker289 What's a Dremel?
    22 Jan 2005
    hmm imo that cover for the hole you made looks kind of dorky imo. i would bondo it and then remount the port somewhere else. but this is just my opinion :blah:
  20. Bboy_Jon
    Bboy_Jon Minimodder
    28 May 2004
    well theres no other place to mount, i would bondo it but i dont have any, if i find some ill buy some
