Project: Chrome Dragon? *UPDATE* DONE!! NEW PIX!
Discussion in 'Project Logs' started by Bboy_Jon, 1 Feb 2005.
  1. Morphious
    Morphious What's a Dremel?
    19 Jan 2004
    You can get Bondo at pretty much any hardware store, an automotive store if you have one by you, and Wal Mart might even carry it.
  2. CaseyBlackburn
    CaseyBlackburn Network Techie
    27 Jul 2004
    yeah the cover looks very stupid i mean you first off got a huge hole underneath it and then you add this ugly eyesore on top of it and the cover is just a........ square well rectangle and i has nothing to do with the look of the pc
  3. Bboy_Jon
    Bboy_Jon Minimodder
    28 May 2004
    the velcro has "permanent" adhesive so can i still get it off to bondo it?
    theres not a huge hole under it, the hole is perfect to fit the ps1 adapter
    OO i have an idea with the bondo if i ever get it
  4. CaseyBlackburn
    27 Jul 2004
    the width may be perfect but the height is too large
  5. Bboy_Jon
    Bboy_Jon Minimodder
    28 May 2004
    i think its fine
    but anyways i couldnt think of how to explian this and what not, but here goes (btw where in walmart would bondo be if they have any)
    Im gonna cover up the hole so theres just enough room for the controller to fit, and the hole i drilled for the cable tie (if i can get the velcro off), and im gonna make some "walls" that go down to the case itself so you cant see the case all you can see is the controller port
    edit: hmm i think i may do this possibly for the top window
    except i also have a window in the same position on the other side panel, so you see right through the case. Then i dunno what to put on the bottom half and on the bottom half of the other side
  6. Dean_j2001
    Dean_j2001 What's a Dremel?
    1 Apr 2003
    what's it called in england and where can i get it from in the UK?
  7. striker289
    striker289 What's a Dremel?
    22 Jan 2005
    bono aka bodyfiller can be found in the autmotive sections of about everystore or at a autostore. :D
  8. Bboy_Jon
    Bboy_Jon Minimodder
    28 May 2004
    hopefully at walmart, so it would be in the auto section of walmart?
    what about home depot, where would it be?
  9. Neo4
    Neo4 What's a Dremel?
    15 Oct 2004
    good work on that case :)
    for 30$ that case!!!oh my god!
    here is costs about 150$
    the only think i would change is the color.i prefer alu color or black and orange :D
  10. Bboy_Jon
    Bboy_Jon Minimodder
    28 May 2004
    ya i think ill paint it chrome and the inside white :D
  11. GigantoR
    GigantoR What's a Dremel?
    21 Jul 2004
    WalMart carries bondo. For work like that I would either use a bit of your mesh as a base because normal bondo can be pretty brittle, or use the bondo that has fiberglass in it.
    Your chrome paint idea is probably not going to come out how you want. Chrome paints seldom give you the finish you want. As for white, great choice, its what I'm doing. :rock:
  12. Bboy_Jon
    Bboy_Jon Minimodder
    28 May 2004
    are you gonna paint soon? i would like to see how it turns out before i do it
    How would i polish my case? i kinda want to keep it silver but i dont want it to be as dull as it is right now (i want a lil shiny) i dont think its really paint except for maybe the top
    oo were in walmart would the bondo be located in? and do they call it somethin else over there?
  13. GigantoR
    21 Jul 2004
    I have it painted white already, let me look to see if I have any pics.
    The bondo and sandpaper you're looking for are in the automotive section at WalMart.
    You polish you rcase by using very fine grit sandpaper and wet sanding, then using rubbing compound. I don't know if you could do that with the factory finish though? You might be able to put a layer of clearcoat on then use rubbing compound on that. Not sure, somebody correct me if I'm wrong.
  14. Bboy_Jon
    Bboy_Jon Minimodder
    28 May 2004
    ook you made it seem like you were dong it cuz u said "thats what im doing" lol
    pics would be nice, aight so my next trip to walmart i need paint, sand paper, bondo and my ps1 lcd (hopefully they have it)
  15. GigantoR
    21 Jul 2004
    I would link you to my thread, but unfortunately my bandwidth is exceeded at the mo, once I get it back up I'll show you. Or get ahold of me on AIM or MSN.
  16. Bboy_Jon
    Bboy_Jon Minimodder
    28 May 2004
    aight well i tried you on aim, and your not on, i can wait or just im me my sn is breakerdawgbob
  17. Bboy_Jon
    Bboy_Jon Minimodder
    28 May 2004
    OK i think i may have gotten a window, what ya think?
    Hows it look? I good do the dragon on the top side, or i can do the 2 rounded rectangle windows on both side panels so you can see right through the case, and the dragon on the middle/bottom of the right side (the side where u see the back of the mobo)
    ya so either like in the pic, or the 2 round/rectangles on both side panels and the dragon on the non mobo looking side
    what ya think? How exactly could i cut the dragon? i doubt i can do it with a big cutting disc, do i use this?
    or like one of these tungsten carbide cutters?
    is that right?
    so ya what do i use and should i put the dragon like in the pic, or on the other side panel and do top rectanges on both sides, and figure out another window for the mainside?
    if i do the dragon like in the pic, what will i do on the other side panel?
  18. adamjones01101
    adamjones01101 Minimodder
    29 Jul 2004
    Have fun Dremeling that...lol...It has more sharp curves and edges than even mine does. Good luck, though, it's a sweet case panel design. If you want to know what tools I used to do mine so far, there's a list of them in this post.
  19. Bboy_Jon
    Bboy_Jon Minimodder
    28 May 2004
    that high speed cutter killed my case, i tried to cut a lil and it like took a bite outta the case and kept getting stuck
    or should i do this?
  20. CaseyBlackburn
    27 Jul 2004
    i perfer the dragon but that would be easier
